Hey guys,
I'm replacing the PCV system in my S70 GLT with 285k miles and I have a couple of questions that I can't find answered in the walk through's.
1) When replacing the box, I understand that it says to clean out the ports on the block. Neither of the ports on my system seemed to be clogged... at all... Is there a picture somewhere of what I should be looking for? Is it normal for there to be no meaningful sludge buildup in those ports?
2) the breather box/catch can was completely empty, but I replaced it just to be safe. Again, is that typical?
3) With the engine block ports clear, and the breather empty, what would cause the positive pressure? Is it that the hoses were broken and it requires vacuum from the intake to eliminate the positive pressure?
4) Finally, I realize that I have never cleaned the PCT valve... If that is clogged (I'll check tomorrow) does that basically defeat the entire purpose of the PCV system?
Thanks in advance guys.
PCV replacement questions.
- clarkerussell
- Has thanked: 20 times
- Been thanked: 4 times
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
There is a lower port in particular (the lowest towards the bottom of the engine), needs a hose that fits tight in there (may wrap the end of it with some duck tape), then blow at the other end and listed for oil bubbling inside the oil pan. Should be quite easily to blow through it.
Very wise decision to replace the breather box even when perfectly empty. Had the same and put it back, the glove was still inflating slightly, removed everything again then put a new breather box, not it sucks the glove with force. These breather boxes do also crack or fail inside at some seal or diaphragm (such as on non turbo engines).
Positive pressure would be from another clogged passage on the pcv hoses, in particular the turbo engine needed everything really cleaned up or better, replaced. So possible for the PTC valve indeed.
The glove should suck in quite nicely On my S60:
- Has thanked: 1611 times
- Been thanked: 4075 times
Broken hoses will cause positive crank pressure
The PTC isn't a valve, it's just an orfice. It needs to be cleaned every 50,000 miles. If it's plugged, the PCV system fails, correct.
Replace all the 16 year old , oil soaked, baked plastic pieces with new Volvo stuff. If you enjoyed the Labour part of this job, use the cheap parts and then you can do it again in one year.
tardcart
- Year and Model: 96 850t. 93 940t
- Has thanked: 3 times
- Been thanked: 37 times
PTC I wounder what that stands for. the T must be temperature. I hate calling it a valve too, maybe restrictor would be a better term for it. or heater. I hope you got the new long lines, they are always brittle and cracked in their insulating sleeve if original.
- clarkerussell
I got the whole original Volvo kit from FCP. I used URO last time (many moons ago) and they were basically dust when I took it out. I'm not sure how long they had been that way, but I'd say it's been quite some time...
I'm not messing around with questionable parts as I want to use it for my daily driver again. At least for another year to get it to 300k miles! My dad bought the car new and it's certainly not as pretty as before, but it has a special place in the family. I've replaced the starter + wire, I'm doing the PCV/PTC, replacing the leaking power steering pump, replacing all motor mounts, and wires/plugs/cap. The timing belt was done about 10K miles ago, so I'm good there...
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
The last one I did I decided to upgrade the long pipe. I obtained some soft copper from an A/C supply that was the same size as the black plastic pipe and bent it to match, then put the elbows on it and wrapped it in the insulating sleeve. I expect it won't ever crumble now.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
tardcart
the metal lines will, I'm guessing, clog up with condensation mixed with oil unless you insulate them like the factory did. but it will take 6 years and most of these cars won't be on the road in 6 years.
- clarkerussell
So I pulled the PTC and it was clear. There was a little bit of buildup, but I could see straight through. I still spent some time scraping and spraying cleaner on it. The rubber boot for the PTC was in near perfect condition and there was minimal oil in the tube itself.
I'm hoping that the rigid hoses from the PTC to the box were at fault originally and that's what was causing the positive pressure...
Do all the hoses on the air intake (PTC valve hoses, and the other ones) need hose clamps, or just the large hose to the breather box?
- clarkerussell
So is this the test? Basically attach a hose to the lower port (the oil return, right?), seal it up, and blow through it to make sure the port is clear?oragex wrote: 12 Feb 2019, 02:19 There is a lower port in particular (the lowest towards the bottom of the engine), needs a hose that fits tight in there (may wrap the end of it with some duck tape), then blow at the other end and listed for oil bubbling inside the oil pan. Should be quite easily to blow through it.
dustyou
- Year and Model: 98 s70
I am broke. 98 t5 221k. Slight positive pressure, pushing oil either cam seal or crank. Been busy, driving 2 years this way. Finally got a day off and used a hard plastic beverage holder and ran a line off the tree and the other inside the dipstick tube via one of the hose ends, the one end has a outer dimension that seats right in there. The container holds 30 Oz and fits against fan housing. Been getting that white shit on the dipstick in cool weather for 30k miles. Knowing the issue I changed the oil every other month or 1500 miles. Smells like gas. This has smoothed out the shifts, turbo still fine, no lights smooth idle still sucking glove in the oil cap now, might even quit leaking, who knows. If I get time in the future I will tear down the intake and oven cleaner the box 5 times and vacuum while picking the port open on the bottom. Likely plugged. If it blows up or fries the intake or something I will update. Drive it 6 miles twice a day daily basis. Good test. I changed 8 quarts of the trans fluid and it smoothed out somewhat but when going down a hill it would pound third often. Doesn't now at all.pretty cool and I am surprised nothing on YouTube or here to get one by.
