Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Re: What did you do to your Volvo today? (now Sticky!!)
Post by Rattnalle »
tysauce1986 wrote: 12 Feb 2019, 16:41 Changed the oil/filter drain plug washer at 359,000. Liqui moly 10-40. Mann filter. Pulled the Volvo 20 valve spark plug cover to soak up a bit of oil that I assume passed by the filler cap gasket. Recently i had opened the filler cap and looked down at the exposed cam shaft. It appeared to be bone dry. I swiped the cam with a finger and sure enough there was 0 oil present. This leads me to believe that if the car sits for a couple days the top end is running dry at start up. Has anyone else experienced this? Did liqui moly help?
The oil will drain. Completely normal. Just like the walls will eventually be dry in the oil can if you slosh it around then let it sit. However there should still be pools of oil up there that gets thrown around a bit when it starts moving. I doubt any fancy additives will change that.
Has thanked: 1505 times
Been thanked: 3818 times
If you look deep enough on car fora you will find statements like
"90% of engine wears happens on startup"
And if you look deeper on that there is no evidence to this claim other than additive marketing
How would you begin to test for such a thing? Test 100 engines that have many cold startup cycles vs others by disassembly?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Ocelot wrote: 13 Feb 2019, 00:38 That is an awesome story! I have a revenge story of my own, well, it's not really revenge and not nearly as cool as yours, but it think it to be cool anyway. So this happended a few years back when I was 22 years old and I owned a Ford Fiesta mk1 at the time. For those who don't know, I'm 2.05 meters tall and I'm built like a Dutch version of Bud Spencer (that's how my friends describe me and I love it since Bud is one of my hero's from when I was a kid). But you can't really notice that when you put someone like me in a car like that (by the way, the leg and headspace in that car were crazy, I had enough space all around).
So one day I'm cruizing down to the city of Vlissingen and the shortest route was through Belgium. So I did, but the highway of Antwerp is notoriously dangerous. Many accidents happen there and that day was no exception. So I'm stuck in traffic and the thing I do when I hit traffic is that I keep a bit of distance - like say, two to three cars - from the car that is in front of me. In that way, I can just put the car in second gear and let it idle instead of the usual throttle brake throttle brake routine. The guy behind isn't having that and starts to get on my tail like, I can't even see his headlights he's so close on me. I ignore it, the traffic jam is on all four lanes and nobody isn't going anywhere soon. The guy starts to flash it's high beams and shortly after I can see him flipping me of and mouthing the words F-you. The only thing I can do is laugh, for real. Where do you wanna go? Do you see a free lane I'm blocking you from?
Suddenly, I see him braking very hard and getting out of the car with a lifehammer in his hands (the things give out because they're bright orange). I don't think for a second and get out of my Fiesta. Remember, I'm 2.05 meters long, 120 kilo's, Dutch Bud Spencer. The Fiesta lifts a couple of centimeters up when I got out of the car and the guy just freezes in his tracks. I ask him what his problems are while walking at him. He just walks back to his car, sits, and locks all doors. Not a single word. Not a peep. All I can do is laugh. Aah, the memories :mrgreen:
That must have been a great feeling! All you needed to do is get out of your car and he backs right off!
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
I feel like I pictured this beautifully in my head. I'm rolling. :lol:
Rattnalle wrote: 13 Feb 2019, 01:25
Molybdenum disulfide is the one additive that is great for cold starts. It sticks to metal surfaces and creates an amazingly low-friction environment. It provides superior protection at cold start and during a catastrophic loss of oil pressure. So yes there are additives that reduce wear during cold starts even if the engine has been sitting for a while.
abscate wrote: 13 Feb 2019, 03:34 If you look deep enough on car fora you will find statements like
That's exactly how you would test it. Not sure any oil companies actually do such tests anymore. Probably done in computer simulations with theoretical data and parameters.
Technically more wear would happen at start up on a cold engine, but most engines should build oil pressure almost instantly. I would think within 60 seconds of turning the key, your engine would be pretty well lubricated.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
Rattnalle
Post by Rattnalle »
WhatAmIDoing wrote: 13 Feb 2019, 08:39
It won't change the fact that the oil will have drained away from surfaces and pooled at the bottom where there are cavities.
Personally I'm betting that if the Moly was such a game changer everyone would use it or recommend it. But either they don't or they do but it isn't a big deal. Engines often last much longer than the rest of the car either way if serviced.
tysauce1986
Year and Model: 1995 850 GLT wagon 5
Has thanked: 7 times
Post by tysauce1986 »
[/quote]
I think I agree with you. The engine has gone this far with proper. Maintenance. But I'm willing to give liquimoly a shot.
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
Rattnalle wrote: 13 Feb 2019, 09:39
Last night I peeked through the grates and oil was still pooled under the cam. My car had not been started for a couple of days. So even if the cam was dry, it would be wet with oil as soon as it hit the puddle under it? Just my thoughts. I still feel my engine is being better protected by the ester based Redline oil. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
Metal on metal for seconds, or even a minute, isnt damaging as long as the engine isnt loaded. Thats why you can show those trick videos of running an engine with an empty sump for a minute or two without damage.
Oil gets pumped around the cams and splash lubes pretty quickly.
Once you ask the engine to start moving 2 tons of Swedish steel, the oil pressure is important.
tysauce1986
abscate wrote: 13 Feb 2019, 13:20 Metal on metal for seconds, or even a minute, isnt damaging as long as the engine isnt loaded. Thats why you can show those trick videos of running an engine with an empty sump for a minute or two without damage.
Working as an apprentice machinist, the thought of no lube makes me cringe a bit. So while it may be a valid concern i realize it will be ok. Thanks all for your responses.
bmdubya1198
abscate wrote: 13 Feb 2019, 13:20 Once you ask the engine to start moving 2 tons of Swedish steel, the oil pressure is important.
My wagon's only about 3,400 pounds according to the scale at the scrap yard :mrgreen:
