Sheared water pump bolt
- RickHaleParker
- Been thanked: 979 times
Can you get a nut started on the broken bolt? You might be able to bond a nut to the broken bolt with permanent Loctite (Red) or JB Weld, then turn the bolt out.
Active
Past
Past
- RickHaleParker
If there is enough space to get a pair of vise-grips on it. He stated the bolt was behind the "unibody". I'm assuming he is saying there is not much space to work in. Hence his comment about pulling the engine.cn90 wrote: 13 Feb 2019, 21:00 When the broken stud is protruding out, all you need is vise-grip pliers and it is out.
If he had a view of the bolt head-on and he could get one thread of a nut started, he could thermal weld the nut on. Then wrench it out.
Active
Past
Past
- callahanoffroad
- Year and Model: 1995 850
- Has thanked: 16 times
- Been thanked: 53 times
That's actually the solution I came to! But I already closed the project up for the time being. Every day my car doesn't run is $150 I'm not making from driving.RickHaleParker wrote: 13 Feb 2019, 20:18 Can you get a nut started on the broken bolt? You might be able to bond a nut to the broken bolt with permanent Loctite (Red) or JB Weld, then turn the bolt out.
So it's been driving for two solid days with no leaks. About 260 miles. Currently tracing down the cause of the rough idle. Replaced the plugs, that helped a bit. Then I suspected the cap and rotor. Cleaned the contacts and that helped a lot. So I ordered a new cap and rotor. Attached is a picture of the old rotor before I cleaned it.
If it's not that then I'll have to triple check the mechanical timing by hand again.
- Been thanked: 4068 times
That looks pretty torched. I would put new one on, and get a real Bosch and cry once....
- callahanoffroad
Yep that's exactly what I did.abscate wrote: 14 Feb 2019, 08:36 That looks pretty torched. I would put new one on, and get a real Bosch and cry once....
Still idling a little rough, so now I get to check the mechanical timing again this weekend. Maybe I got it off a tooth.
It's probably described by the word "racing" it's like the engine is excited and wants to review up. Then there's an occasional light stumble. So it overall ends up being lightly off balance and vibrating. Maybe I'll post a video tonight. Everyone loves s YouTube video of an engine idling....
Knowprblm 97
- Year and Model: 850 GLT
Volvo 850 1994 n/a. Snapped water pump bolt flush to the head. Drilling bolt left oval hole as drill bit wandered during drilling. I'm left with oval shaped hole where the bolt was. What is the best way to repair? Steel putty or weld
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Might be helicore time if you need that bolt. I believe OP just left his out.
1999 V70 GLT
1999 V70 GLT
I think I would JB weld it, the drill and tap the JB weld for the M6 bolt. Some recently did this successfully here
- RickHaleParker
It can be done with out a drill and tap.abscate wrote: 15 Apr 2021, 02:17 I think I would JB weld it, the drill and tap the JB weld for the M6 bolt. Some recently did this successfully here
- 1. Find a bolt that fits in the hole.
2. Dip the bolt in molten wax and let it cool.
3. Push JB Weld in the hole.
4. Put the bolt in the hole.
5. Wipe off excess.
6. Let it set up for 10 minutes or so.
7. Clean it up with a rag damped with Acetone. Damp not wet.
8. Let the JB Weld fully cure.
9. Wrench the bolt out.
Use the original long cure. Is much stronger than the quick cure.
Keep in mind the surface needs to be clean, squeaky clean, or the JB Weld will not bond to the metal in the hole.
Active
Past
Past
- 10 Replies
- 3672 Views
Last post by sleddriver
- 876 Views
Last post by leucadiacruiser
- 29 Replies
- 4904 Views
Last post by volvolugnut
- 919 Views
Last post by GreenMagicMan
- 862 Views
