2002 volvo v70 turbo boost pressure sensor 9125462
petervee
Year and Model: 2002 v70
Re: 2002 volvo v70 turbo boos pressure sensor
Post by petervee »
OK. Got the part. However, I cannot find where it goes. The neckwhere the number 6 hose joins is smooth...there's no sensor. Is it perhaps inside the neck...do I have to take the number 6 hose off to get at it. It certainly is not on the outside where the diagram above shows.
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 55 times
Been thanked: 39 times
Post by EngineeringBloke »
It is not mounted on the hose, but on the port from the intercooler that the hose fits. Follow the hose back the the intercooler and you should see the sensor and its wires.
petervee
Post by petervee »
Nope not there or anywhere else I can find. I believe my model (2002 volvo v70 xc AWD wagon) doesn't have this part. I ordered the #4 in the diagram above. This has the name of MAP boost pressure sensor. Hopefully this solves the problem. I actually consulted a guy who knows Volvos pretty well and he said that was the correct part.
XC70Rider
Year and Model: 2007 XC70
Has thanked: 35 times
Been thanked: 41 times
Post by XC70Rider »
Take a peak at the throttle intake pipe.
petervee
Post by petervee »
exactly..that's thepart on the right
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
# 4 = MAP sensor.
#12 = IAT sensor.
#18 = Boost Pressure Sensor.
It is a full HD picture (1920×1080), click on it to zoom in.
petervee
Post by petervee »
18 DOES NOT EXIST ON MY CAR...wrong diagram.
RickHaleParker
That is the diagram for a AME 2002 V70 with a B5234T3. You sure you got the right car?
Has thanked: 1504 times
Been thanked: 3817 times
Maybe an early 2002 that still has the bastard pressure and temp sensor down on the induction hose before the ETM?
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Even as far back as 2000 MY P2 turbos had the 2 sensors on that hose.
What is the build date on that car?
