TerryJr - this gets the post of the Month award for crappy parts awareness
That is terrifying for a new part.
This will get cross-posted to the P80 and P2 Fora
GoPro on a low quality control arm
- Been thanked: 4064 times
terryjr
- Year and Model: 06 XC90 - 04 XC70
Haha thanks. Just swapped on MOOG arms and it feels safe again. Needs an alignment and new tires but I could see the bushing quality was night and day.abscate wrote: 14 Feb 2019, 12:06 TerryJr - this gets the post of the Month award for crappy parts awareness
Those ultrapower or sks arms really are unsafe right out of the box
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
I would have liked to see how it acted over a manhole cover/rail crossing/pothole ~2-3 inches tall or deep. I think you would have seen the rear portion of the control arm moving up and down to possibly/eventually start banging against the subframe. I saw evidence of this with the 'IPD HD' control arms on my S60 a couple years back..right from the start. The S60 uses a like bushing/front suspension configuration as the XC90 with differences being mainly dimensional.
IPD may well have reworked their bushes since then. Or I could have been unlucky and merely got hold of a 'bad batch' that doesn't affect everybody. But I have no way to know. Between those LCAs, their house branded hd end links that didn't last a year (paper thin grease boot disintegrated/split open), and seeing reports how their rear adjustable stay arms were breaking on people/pulled from sale...made of welded aluminum as opposed to welded high grade steel that *every* OE design I've ever seen uses in that sort senerio... I've pretty much decided to stay away from much anything they come up with on their own. You can't go reworking an OE design without 'OE level expertise' with regard to mechanical engineering/wear testing/performance analysis. Which is probably why the vast majority of aftermarket parts suppliers strictly duplicate OE designs and *don't* try to reinvent the wheel - because proper 'R&D' involved in modifying an OE design is costly.
- 10 Replies
- 3850 Views
Last post by WhatAmIDoing
- 13322 Views
Last post by MarcM
- 2942 Views
Last post by 800artfreed
- 2491 Views
Last post by Volvo Kush
- 11 Replies
- 5266 Views
Last post by mrbrian200
