hi..
to update .. changed the abs part. worked fine. but now again the same problem. maybe 2 months after installation.
could it be just bad luck that the part was not in good condition it broke again or should i check for another problem that might cause the unit to malfunction
thanks
Abs system
- Year and Model: Lots
- Been thanked: 128 times
Many cars at junkyard end up there because of multiple problems. The last problem was the one that caused owner to give up on the car. At this age most used modules are faulty.
You can send your original module to BBA Remanufacturing and their fee is quite reasonable. They will refund the inspection fee if they can't repair.
- 55 Replies
- 5132 Views
Last post by manovlov
- 1944 Views
Last post by Capndirk
- 719 Views
Last post by RedBrickCollector
- 560 Views
- 1452 Views
Last post by tsteenka
