Although ETMs (throttle bodies) sometimes are sold with a note that they need to have software uploaded. This just is not true - at least for my 2006 S60 2.5T.
The throttle body does not sit on canbus. It has a connection that provides a pair of wires to drive the throttle stepper motor open or closed, and a ground and positive supply for use with the two potentiometer outputs that report throttle position. There are 6 pins in the connector and that accounts for them all. No software in here at all.
This afternoon, I replaced my 2006 Bosch/Volvo ETM with a Chinese 'clone'. I took a look inside the gearing box and was surprised and pleased to see that the system used magnetic position sensing instead of the resistive tracks that have failed on some throttle bodies.
I took a test drive and the car seemed a little smoother than before. I had left the key in position 2 for a couple of minutes which should run a calibration, but was not able to tell if it had run.
Anyway, clearly no software update was needed for this.
Swapping a used modules works, they aren't crippled by vin coding Topic is solved
EngineeringBloke
- Year and Model: 2006 2.5T S60
- Has thanked: 57 times
- Been thanked: 39 times
- Year and Model: Lots
- Been thanked: 128 times
I don't think that anyone has stated here that a Bosch throttle requires programming. They only require a quick ignition on PosII calibration. Really good to hear that the Chinese clones use magnetic technology. Was it from OK Motors?
The Magnetti Marelli throttles up to MY 2002 are another story though.......
deano1
- Year and Model: 2001 s60 1999 awd
- Has thanked: 13 times
- Been thanked: 17 times
EngineeringBloke
Your post is a little misleading.
I know for a fact that you can't just swap ETM's from one car to another.
I grabbed ETM at scrapper from a 2.4 n/a and swapped it onto my 2002 2.4 n/a and although the engine started it was still un drivable.
So i think it's possible when you purchase those units from Xemodex or that contactless Chinese unit the software is preloaded?
Am I missing something?
Cheers
Cheers
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
EngineeringBloke and precopster speak the truth. If you have an early P2, like up through 2002 with the Magnetti Marelli throttle, then yes it will likely need programming. I've never owned a so equipped car but I believe what everyone has reported.
But on the later P2's with the Bosch throttle, it's plug-n-play - no programming required. I can verify because I've done it.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
As mentioned above, on 2003 and up it's a different throttle body that doesn't need programming. It is good you are pointing this up, because it's good to know that - unfortunately - the Bosch throttle bodies also go bad, I think most likely after 2006 and up for some reason. I was reading a site with car reviews, many 2006+ owners did pay a hefty sum at the main dealer to have their TB replaced - when in fact they could have easily just swap a used one from 2003(?) up (better go with a similar year)EngineeringBloke wrote: 16 Feb 2019, 17:21 for my 2006 S60 2.5T. no software update was needed for this
On 2001-2002 a swap with a used TB may or may not work without programming, it will depends on the serial numbers, software version, etc. For some people worked plug and play, but for most it didn't and programming is not really possible as the main dealer usually doesn't touch a used part.
Thread appears to be old but here is something to think about:
Swapped an 04 XC70 refurbished broken ABS module with an 03 XC 70 and check engine and light went out, pedal/brakes/abs pump all work fine BUT now there are a plethora of new codes:
ABS-0114
ABS-0130
ABS-0133
ABS-0139
ABS-0140
ABS-0076
Last one is faulty configuration.
Brake pedal sensor was replaced as well.
JSUK
ABS-0114
ABS-0130
ABS-0133
ABS-0139
ABS-0140
ABS-0076
JSUK
- 13 Replies
- 4115 Views
- 1185 Views
Last post by Sspire0124
- 3481 Views
Last post by jimmy57
- 1005 Views
Last post by ferocity02
- 257 Views
Last post by 1990Volvo740
