White/Blue Smoke from the Tail Pipe 97 R Wagon
Jhagins1
Year and Model: 97 855R
Post by Jhagins1 »
Thanks guys! I will check and see if the turbo is still in the garage and pull the other one.
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
Do you especially notice this after coasting in gear?
Jhagins1
Post by Jhagins1 »
Honestly it is more on start up or when it has been sitting for about 30 minutes. The other time it happens is when I boost. I did not know but my boss was following me and did that he thought it was a diesel.
Jhagins1
Post by Jhagins1 »
I don’t have the original turbo anymore. I pulled the intake hose and have a small amount of oil in the intake flange going into the turbo and also in the intake tube at the ptv.
Jhagins1
Post by Jhagins1 »
And to reply to Reys. I did not rebuild the turbo it was a eBay buy which I know is not the best but after 1k for the car, 1k for the shipping and 2k with parts and all the other stuff i need a little break on the bank. I will pull the exhaust side of the turbo apart tomorrow before work when I can get a bay and lift and let you all know what I see.
Been thanked: 4065 times
Look at the bright side, you are halfway home
eBay stuff is usually just unbolted from Junkers. The turbos on these cars as every bit as the acclaimed Japanese ones though, they rarely go bad
Oil in the induction hosing is normal
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
Are you sure you were burning oil when boosting and just not running rich? Oil would be blue/white, but black smoke is excess fuel. In my T5 under high boost, my ECU seems to be dumping as much fuel as possible into the engine, which can produce a little black smoke (not sure it's suppose to though).
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
Jhagins1
Post by Jhagins1 »
No it is blue white
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
So, you said the PCV system was done. Does it actually pass the "glove test"?
On a 300K motor, I would actually do the "high-mileage" mod on the PCV (Larger hoses from the trap and opening up the PTC port).
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
Also... and it’s a long shot ... are you sure you got the PCV hoses on the right way? There’s a schematic floating around somewhere where the hoses aren’t connected correctly. Been a while since I’ve seen someone have that issue, but still...
- S
[Sold] '97 S70 T5
