White/Blue Smoke from the Tail Pipe 97 R Wagon
Jhagins1
- Year and Model: 97 855R
Honestly it is more on start up or when it has been sitting for about 30 minutes. The other time it happens is when I boost. I did not know but my boss was following me and did that he thought it was a diesel.
Jhagins1
And to reply to Reys. I did not rebuild the turbo it was a eBay buy which I know is not the best but after 1k for the car, 1k for the shipping and 2k with parts and all the other stuff i need a little break on the bank. I will pull the exhaust side of the turbo apart tomorrow before work when I can get a bay and lift and let you all know what I see.
Look at the bright side, you are halfway home
eBay stuff is usually just unbolted from Junkers. The turbos on these cars as every bit as the acclaimed Japanese ones though, they rarely go bad
Oil in the induction hosing is normal
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Are you sure you were burning oil when boosting and just not running rich? Oil would be blue/white, but black smoke is excess fuel. In my T5 under high boost, my ECU seems to be dumping as much fuel as possible into the engine, which can produce a little black smoke (not sure it's suppose to though).
Knows enough to be dangerous
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
So, you said the PCV system was done. Does it actually pass the "glove test"?
On a 300K motor, I would actually do the "high-mileage" mod on the PCV (Larger hoses from the trap and opening up the PTC port).
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Also... and it’s a long shot ... are you sure you got the PCV hoses on the right way? There’s a schematic floating around somewhere where the hoses aren’t connected correctly. Been a while since I’ve seen someone have that issue, but still...
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- 10 Replies
- 1776 Views
Last post by erikv11
- 12 Replies
- 957 Views
Last post by xHeart
- 2063 Views
Last post by RickHaleParker
- 1825 Views
Last post by volvolugnut
- 1184 Views
Last post by FireFox31
