What Is This Piece Called? - 2003 S80 Topic is solved
Starts but won’t drive will reverse
- 90ACDC66-DB4E-4BBF-8530-60E4EF1C549F.jpeg (805.06 KiB) Viewed 4168 times
Reason: Edited title. Please, no "!!!???"s in titles.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
That is the electric brake booster vacuum pump switch. That switch failing will only case hard brake pedal for a minute when cold.
Is the transmission fluid level OK?
