I have a 97 960, and it has the blinking light from the ac. All the controls work fine, but no heat.
The lines to and from the heater core are hot. But no heat... can anyone help?
I don’t really want to run the codes at the dealership for $100 before trying to fix it myself.
960 heater not working
- RickHaleParker
- Been thanked: 978 times
The blinking light means the EEC has detected a fault.
SELF-DIAGNOSTIC SYSTEM
The EEC system incorporates a self-diagnostic function that indicates system faults through a series of trouble codes. The presence of fault(s) is indicated by flashing A/C OFF button. The control panel is programmed to enter a pre-programmed mode when a fault is detected. Under fault condition, control panel ignores the faulty signal, selects an alternative pre-programmed value and prevents delivery of faulty output signals.
To enter Self-Diagnostics mode:
8. Request a code:
Three different fault codes may be stored in memory. However, only one code may be displayed upon request. It may be necessary to request display of fault codes a number of times to ensure all fault codes are displayed (Step 8 above).
Exiting Self-Diagnostics & Clearing Codes
To exit self-diagnostics, turn ignition off. All codes are cleared when ignition is turned off. Fault codes are not stored in memory. Even if a code has occurred several times during a period of time, code will only be stored until ignition is turned off.
TROUBLE CODE IDENTIFICATION TABLE
Affected Circuit/Sensor Code
161 = Solar Sensor
Servomotor/Potentiometer
- 1. Ensure engine is running.
2. Shine a non-fluorescent, bright light on solar sensor (LED on the dash).
3. Place blower fan control knob in AUT position
4. Function selector knob in vent position.
5. Place temperature control knob to maximum cooling (pointing straight down).
6. Ensure recirculated air switch is depressed.
7. A/C OFF button is released.
8. Request a code:
- Depress and release A/C OFF button within 5 seconds to start self-diagnostic mode.
- 111 = Fault Free System
- 121 = Short Circuit To Ground
122 = Open Circuit Or Short Circuit To 12 Volts
- 131 = Short Circuit To Ground
132 = Open Circuit Or Short Circuit To 12 Volts
- 141 = Short Circuit To Ground
142 = Open Circuit Or Short Circuit To 12 Volts
161 = Solar Sensor
- 211 = Open Circuit Or Short Circuit To Ground
212 = Short Circuit To 12 Volts
- 213 = Incorrect 12-Volt Supply To Pins No. 17 & 18
214 = Fails To Operate Within 10 Seconds
- 231=Faulty Temperature Control
233 = Fan Motor Excessive Starting Current
- 241 = Coolant Valve
242 = Bi-Level
243 = Vent
244 = Recirculated Air
245 = Defrost
246 = Floor
247 = Fan (Maximum Speed Relay)
248 = A/C Compressor
249 = Radiator Fan Relay
Active
Past
Past
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
Is the blower motor not running? If not, the blower motor isn't necessarily the problem. The code about the blower motor starting voltage is related to the ECC power stage. More than likely the ECC Power Stage has gone bad. I installed a ballast resistor and switch to power the blower motor on my 1988 760 with ECC. Without the ballast resistor the fan ran at full speed.
1988 Volvo 760 Turbo Wagon
- 355 Views
Last post by Caffeind
- 1253 Views
Last post by Ozark Lee
- 1532 Views
- 559 Views
Last post by Stingray06
- 10 Replies
- 4033 Views
Last post by Wetlander
