Nivomat and the Stabilizer bar
jeffsws
Year and Model: 850 NA 1997
Has thanked: 3 times
Been thanked: 3 times
Post by jeffsws »
Hello.
I'm adding nivomat shocks and nivomat springs to my car. I see that the stabilizer bar may need to be changed as well; I hope not, though. Stabilizer bar 9191461 is specific to nivomat according to Vida.
O.DIA 20.8 mm, NIVOMAT. MARKED P
For vehicles with lowered chassis.
How important is this? And would converting an existing nivomat car to regular shocks require a non-nivomat stabilizer bar?
Cheers
Jeff
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Never heard about that.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
I swapped my rear nivos for regular Koni Yellows without changing a thing. If your car actually has a sway bar back there, you might need to look into it, but the part is NLA, so you may need to work around it.
The issue is usually that the nivos are phat bois, and need different seats, for example.
Remember that you also need different springs.
- S
[Sold] '97 S70 T5
jimmy57
Been thanked: 322 times
Post by jimmy57 »
Volvo made different chassis tunes and Nivomat was usually the soft ("comfort") tune with smaller diameter stabilizer bars. I don't recall any of the cars with sway bar to shock clearance that tight once shock is installed. I would think any note of sway bar was the diameter difference from the Nivo equipped models for the soft ride.
jeffsws
Post by jeffsws »
Thanks guys.
I'm going to assume that people have used nivomats (and even the standard non leveling shocks) with a range of different sized stabilizer bars, including none at all, which will be the case when I install them. It's a slow 10valve car anyway, but it's used for hauling lots of stuff and it'd be interesting to see if the nivomats help, even without the stabilizer.
