Access Hood Release Latch Through Front Grill
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Hello there,
Recently my front grill came off and i am in the process of reinstalling it.
What i was wondering though was, is there any way to reach the hood latches from the front grill space if the grill is removed first, then reach though the opening or something? It's hard to tell. So this would mean either reaching in or using a custom made tool or something.
Thanks.
Been thanked: 4065 times
It's a lot easier if you rig a wire or string before the cable breaks , and tie off above the air shield
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Rumor has it some have went through the corner lamp area...
Year and Model: Lots
Post by precopster »
I tried the corner lamp no dice on a cable break when I sold the 2000 V70. Ten minutes after I sold it the guy calls me to say he broke the cable so I went out to have a look.
Some have removed the headlight lens and screwed off the lamp covers at the rear. Another headlight will be needed as you need to damage the headlight to get to the cable.
greg850r
Year and Model: a long list
Has thanked: 5 times
Been thanked: 26 times
Post by greg850r »
The safety catch is the only one you can get to through the grill. The primary ones on each corner I have always been able to pop by removing the corner lamp and going in that way.
It did help to have another one with the hood open for reference so I wasn't guessing. I don't remember what I used for the tool though.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
This would be a great video to make, maybe from a PnP?
Do you break the side light to get to the latch or does it pop out and just stretch the spring?
Covered in detail here, and Matty has a good cover on swede speed too
viewtopic.php?f=1&t=53430
MrAl
Post by MrAl »
greg850r wrote: 17 Feb 2019, 00:54 The safety catch is the only one you can get to through the grill. The primary ones on each corner I have always been able to pop by removing the corner lamp and going in that way.
Hi,
How did you get the corner lamp out?
Thanks.
greg850r
Post by greg850r »
I pulled on it. The spring retaining it will stretch. I think I inserted a long screwdriver and unhooked it from the header panel. Alternatively you could clip it with a side cutters and just use a new spring to put it back in.
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
MrAl
Post by MrAl »
Hi,
Oh that's interesting, thanks a bunch. I hate to try this though unless i have to :-)
