Changed spark plugs, now getting new misfires
Been thanked: 4070 times
Nice catch Mike
Wiring is also a definite inspection item and would’ve fit the symptom list
catchmeifucan652
Year and Model: 2009 S60 AWD
Post by catchmeifucan652 »
I took apart the wiring harness and found a couple of spots with cracked wire insulation, particularly with the hot and common wires cracked near a frayed ground going to cyl 2. Cyl 1 and 2 share a ground circuit. I thought I had it figured out, but nope, not yet. Everything is exactly the same.
Yes, the bad cylinders are getting 12V. I'm not sure if that's a good or bad sign for my ECU. I also checked the fuse on the coil circuit and it seems fine, measuring open circuit. A friend suggested an inline spark plug checker, but at this point I don't know what I would do with positive or negative results. This is mind boggling.
I ordered new coils packs, and if that fails, I'll take it to a good shop. I figure the shop is going to make me buy them anyway, so I might as well buy them at an online price and see what happens.
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 45 times
Post by 93SCMax »
Your issue isn't your coils. If you've moved #1 and #2 to other cylinders and they work fine, then they aren't your issue. Good coils moved to #1 and #2 cause a misfire. Replace them if you like, but your issue is strictly with cylinder #1 and #2, either grounding or a wiring issue or something common with both cylinders. Don't let a shop tell you what parts need to be replaced if the data indicates otherwise.
A common ground point for both cylinders, or broken wiring would be the next place to look.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
No misfire before changing plugs. Misfire after changing plugs. Have you considered it might be the new plugs. Try reinstalling the old plugs and see if the misfires go away.
Active
Past
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
I'm quite sure you meant the fuse was measuring closed cicuit. Besides a blown fuse would take out all 5 cylinders.
As above or swapping plugs from "good" location to misfire location if they're already in the trash.
Upthread, the OP replaced new plug so with old working plugs, and misfire remained.
This one is going to be interesting.
RickHaleParker
abscate wrote: 24 Feb 2019, 05:51 Upthread, the OP replaced new plug so with old working plugs, and misfire remained.
I missed that, he did reinstall the old plugs on #1 & #2.
Two things misfire on adjacente cylinders is a symptom of are:
1. Blown head gasket between the two cylinders, which is possible but unlikely in this case.
2. Misinterpreting the layout of the wiring harness and getting the two connectors to the coil packs swapped.
Each of the five coil pack have one wire that is a different color then the other coil packs.
Cylinder #1 Blue wire.
Cylinder #2 Brown wire.
Cylinder #3 Red/White wire.
Cylinder #4 Pink wire.
Cylinder #5 Violet wire.
Active
Past
93SCMax
Post by 93SCMax »
RickHaleParker wrote: 24 Feb 2019, 06:51
Excellent suggestion.
Switching wires by mistake is one reason I only do one cylinder at a time...learned the hard way many years ago.
I fat sharpie mark both coils and connectors on coil on plug cars
Sentry1974
Year and Model: 2005 V70
Post by Sentry1974 »
This post changed my life. Going through a divorce. Bought the car with issues with the intention of trading up from my volkswagon. Previous owner messed up the timing. Turned out it had bent valves. Rebuilt the head. Was running like a pos. Struggled for days researching misfire issues. Found this. Swapped coil wires. Presto. Runs like a dream. Thank you rickhaleparker. I needed the win.
