locked out Topic is solved
ashleybirch
Year and Model: 2011 XC90
Post by ashleybirch »
I will also hire locksmith near me] if see such lock trouble or getting myself in locksout situation.
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Raise the front of the car. Connect a float charger to the positive battery cable on the starter and a ground. This should trickle charge the battery, it might take a couple of days. When the battery is charged enough you should be able to use the remote to unlock the door.
Active
Past
Been thanked: 4065 times
Im afraid MVS was too late on this one...
Screen Shot 2019-02-27 at 2.52.35 PM.png (384.33 KiB) Viewed 1540 times
GraceNoah
Year and Model: 2011, na
Post by GraceNoah »
Thank you so much, your advice helped and locksmith dhave done that job for me at very affordable cost.
tyguyc
Year and Model: 2004 xc70
Post by tyguyc »
I used a piece of string about 5ft long with a slip knot tied loosely and I shimmied it down the door frame till I could loop it around the pull tab unlock thing (wow im bad at naming things). Then pull tight and pull up. took about an hour to get it all right, but I didn't have to call anyone.
TysonWheeler
Post by TysonWheeler »
Car locksmith near me helped me to get back into the car.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
These methods were mentioned in the previous posts.
