Bad koni yellows?
chrillew
Year and Model: volvo 850 T-5R 1995
Bad koni yellows?
Post by chrillew »
Hey
Was changing the top strut mounts both where shot. then i saw that the dampers was really easy to push in when i say easy, i could put the weight of my finger on them and they would compress with no force at all. but getting the shocks out again was another thing, i had to pull for a man and two to get it outwards so i could remount it again.
Sign of a failing shock ?
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
I've never had the luck to have Koni struts so I don't know what is normal behavior is. On the Bilstein struts a good one has decent resistance both compressing and rebounding but the Koni Yellows are usually adjustable. It might be that they just need to be adjusted.
chrillew
Post by chrillew »
I think they where adjusted pretty hard, seemed like they almost compressed by them self just sitting there. but rebound is very stiff.
Weird that the rebound seems to work, but the compression seems ultra soft.
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 37 times
Post by tardcart »
A shock only works on rebound. Its impossible to resist compression, Imagine hitting a pot hole with the shock resisting upward thrust. nothing can resist that. It would blow out the shock or tower.
Has thanked: 293 times
Been thanked: 765 times
Actually something can (and does) resist that - the coil spring! Which is mounted to the strut body for that matter.
But yeah, shocks are for dampening vibration, however they can dampen compression and/or rebound. A compressed spring is always rebounding.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I find compressing them with but one finger suspicious.. but at least I believe they should return by themselves... but again, each shock may be different. I've had several brands on my hands - but not the Koni - and the good ones were returning smoothly and quite quickly, while the bad ones were rather lazy at it or were taking forever. As for the force to depress, some are much lighter than others, but again, using just one finger seems a bit extreme.
But again, I'm no expert, who knows how the Koni are designed.. I'd say, the best way to tell is on the road: nice damping over street bumps, good quick handling at speed, stability, all these should tell. But if you google Koni problem or 'long lasting' you may find these are not the most reliable, at least not as long as a Bilstein
chrillew
Post by chrillew »
Yeah well they are kinda old 5-7 years or so. in high speeds they tend to bounce also even what setting. think i should install the bilstein TCs and compare.
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
I have Koni Yellows, and they’re definitely not supposed to be like that. Mine are pretty stiff all-round, even on the softest setting, do not bounce at all, and I’ve never seen the behavior you describe when I’ve had them off. Something is not right with your set. :(
- S
[Sold] '97 S70 T5
