1998 S70 head job, retiming
Dieselerdie
- Year and Model: 98 s70
So i took this thing apart to do the head gasket and didnt put it in timebefore so. Is there anything i should know or do i just put it in time now and slap the belt on it? Also where can i get some head studs?
- Has thanked: 1505 times
- Been thanked: 3818 times
Standby until one of the guys who has done a good head gasket RR links you up. Getting it timed before you spin it up is important.
- Has thanked: 292 times
- Been thanked: 765 times
So you already installed the head and the cams, or is it apart?
If it's still apart then just put the crank on the mark before you go to the cams, then install those using the slots on the back. With the crank mark lined up, you can freely rotate the cams if/as necessary, and the valves will not hit a piston.
If it's all together and the crank is on the mark you are good to go, just put the cams in time and carry on. If it's all together and the crank is not on the mark then I think I would pull the cam cover and cams, set the crank, and do the procedure above. You'll have to re-do the cam cover sealer, including cleaning the surfaces. You can possibly jockey it into time by monkeying the crank and cams back and forth, but it is a real headache and likely not worth the effort.
Here's one pretty good timing thread, there are a bunch of good ones actually: viewtopic.php?f=1&t=77373
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Dieselerdie
thanks I put it together, all is good. what about some studs?
Do you mean exhaust manifold studs?
https://www.fcpeuro.com/Volvo-parts/S70 ... haust+stud or any machine shop, most auto parts stores - just bring an old stud in.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Renamed thread per rules
Dieselerdie
No i meant head studs erikv11 but i just found some
- 476 Views
Last post by Cook.p.michael
- 4251 Views
Last post by jimmy57
