I don't think unplugging the MAF will eliminate the MAF code though it may run a little better if the MAF is the bad part.
Sounds more like a loose hose......especially around the ETM
when buying a used ETM what will work without a reprogram?
- Year and Model: Lots
- Been thanked: 128 times
Cillyman
- Year and Model: V70. 1999 Base N/T
I have purchased a used ETM that was manufactured in 2018 and pulled from the exact same car and engine as the failing ETM a V70 1999 5 cylinder non turbo. What are the chances that it will not need to be reprogrammed ? Thanks Scott in MA.
About one in four, chances are far greater if both vehicles have been back to the dealer post 2006 for software update.
Hello
I had problems with my ETM.
I have install one with the same reference, and it works, but I think it isnt fine enought, is it possible?? May a reprograming software fix it?? Or if the software is not reprogramed it doesn't work at all??
PD. Sorry for my english
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Yes.cleven wrote: 14 Jun 2021, 23:06 Has anyone actually installed a ETM off a same year car and it worked without programming?
I just replaced my etm in my 2001 v70xc turbo with a same year from u pull it. Goes like a rocket but new code91B7 (throttle position at rest )and dang “engine system service required” msg for first time. Have Vida and replaced the sensor with sacer. Can I use Vida to erase this msg or go get etm number 3? Shame it runs great idle a tiny bit high. Hate going to dealer rather do it myself. Any others with same issue? Thanks from Albuquerque
- Has thanked: 1611 times
- Been thanked: 4072 times
Vida will scrub the code, you can also check your work and see how close your sensors match.
The best solution to ETM based problems now is the late 2014 Volvo built contact less unit, on eBay for $150 or so for the patient.
Thank you! It’s my first post to you guys after reading all your helpful advice. Still have the 91B7 code but idle and acceleration great. Sweep test good. Just still have the engine system service required message. Grrr...
- 1370 Views
Last post by precopster
- 2529 Views
Last post by matthew1
- 2592 Views
Last post by olddaddy
- 3053 Views
Last post by MadeInJapan
- 2649 Views
Last post by mrbrian200
