1999 V70T5M Oil Cooler and seals 30637339 (Biscuit style on rear/RHS of engine
Been thanked: 4065 times
Update
The return hose , part number 30713304 shoes as NLA ON FCP
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
abscate wrote: 01 Mar 2019, 04:30 Update
You sure?
I will do some sole checking, unless your post is just laced with sarcasm.
Don’t you have a server to go check somewhere in Utica?
wizechatmgr
abscate wrote: 02 Mar 2019, 03:10 I will do some sole checking, unless your post is just laced with sarcasm.
Moved the contents of it back to "home." :D
Quick update on this thread
If you are servicing an XC biscuit oil cooler you may need to remove the angle gear damper, a cigar box sized thing box below the gear. Have fun with that one, thread here
viewtopic.php?f=1&t=88994
Does this look right?
Red unfiltered oil
Green filtered oil
Blue filtered and cooled oil
