Yo, abscate, I just spent several fruitless minutes trying to locate "the Volvo parts Lisle site". I remember the red and white Lisle tools throughout my entire car life but I cannot find what you referred to.
Sorry for the "spoon feeding" request but what is this sites address?
Can i use SEAFOAM in my Oil/ or Ect?
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 79 times
- Been thanked: 71 times
Georgeandkira wrote: 02 Mar 2019, 07:09 Yo, abscate, I just spent several fruitless minutes trying to locate "the Volvo parts Lisle site". I remember the red and white Lisle tools throughout my entire car life but I cannot find what you referred to.
https://parts.volvocarslisle.com/
I’ve sent them a couple of suggestion on making their site more friendly like being able to login and save your VINS
crlande
- Year and Model: 240DL;850;S70
- Been thanked: 36 times
Seafoam is/was designed for two stroke marine engines in the '40's. With a little bit of marketing it is also now good for four strokes!
Go with something that has a PEA additive in it if really necessary.
natural4reelz
- Year and Model: 02 VOLVO S60 TURBO 5
- Has thanked: 3 times
Ok thank you
Im still not sure where or what is involve on vleaning the PCV/PVC SYSTEM AND WHERE EACH PART IS LOCATED that Needs cleaned...
Pictures and would show me what needs cleaned and what exactly is a PCV//pvc
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Make sure to replace the PCV box even if you find it empty. The box itself doesn't have to be clogged to be dysfunctional.
- SuperHerman
- Been thanked: 207 times
Your request for pictures and step by step instructions were in my prior post. There with a link that you can click on and it will pop up.
Positive crankcase ventilationnatural4reelz wrote: 03 Mar 2019, 06:48 Ok thank you
Fancy words for the system that captures oily gas from your engine and burns it in the cylinders. On Volvos, if the previous owners didn't change oil enough, the plug up with gunk. After about 10 years the plastic parts on the system get brittle so you replace and not clean these parts.
- June
- Has thanked: 523 times
- Been thanked: 261 times
Also there is a diaphragm in the box from what I understand that can fail. Really if the system needs service you might be better off paying a Volvo mechanic if you feel uncomfortable doing a larger job like that. Do a glove test. I'll attach the photos showing you how. Volvo says never use additives in the oil. 100% synthetic oil will melt the crud away. I switched my car to Redline and all that crud is disappearing on own.i have always had 3000 mile oil changes with "synthetic" dealer oil changes and had that same crud. Over the last 35K the engine crud has incredibly been dissolving. I'll attach photos of the grates 35k apart. Juneabscate wrote: 03 Mar 2019, 17:06Positive crankcase ventilationnatural4reelz wrote: 03 Mar 2019, 06:48 Ok thank you
- 20190203_194241.jpg (312.17 KiB) Viewed 1199 times
- 20190203_194310.jpg (301.98 KiB) Viewed 1199 times
- 20190203_194432.jpg (309.18 KiB) Viewed 1199 times
- 20190203_194545.jpg (355.15 KiB) Viewed 1199 times
- 20190203_194721.jpg (367.61 KiB) Viewed 1199 times
- 20190303_194354.jpg (240.39 KiB) Viewed 1199 times
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
natural4reelz
Thats what i got in now is 100% Synthetic oil....
Can u take pics of the PCV??
U always explain and take such good pics....
You really do!!!
You r a great teacher!!!!
Im not afraid of getting dirty... its im very visual p rson and well you know ....
You really do!!!
These parts are buried under the intake manifold, the big metal thing that looks like pipes cast together at the front of the engine.
It’s a big job to start out on as a beginner, you need help with this one. Just to give you an idea I did my second to last one in three hours, my last one on a less familiar model XC took 12 hours. There were some really hard to access bolts requiring crows feet wrenches
