1999 S70NA Evita dome light 9483142 troubleshooting [Passenger door switch fault]
- Been thanked: 4067 times
Excellent skills, thanks Rick
Hmmm - car is away at indie getting keys made - but I just noticed something
On my 1999 V70 the light switch function order is
ON- DOOR- OFF
The 10/22 diagram above shows order as DOOR OFF ON
I wonder if the switch had a VIN change on it ?
ON- DOOR- OFF
- raivis_rsn
- Year and Model: V70 1999 TDI
- Been thanked: 7 times
It's actually DOOR ZERO position, not DOOR. I gues that confuses you.
The top switch in the diagram has three positions , DOOR -OFF -ON
My car switch has three positions. ON DOOR OFF
It is customary to accurately represent the switch function in an electrical diagram, so one of these isn’t right, tbd.
In any case, a continuity test to terminal 7 on the dome light plug to ground will tell me if I’ve got a ground switch closed when all the doors are open, the most simple failure here.
Stay tuned
Stay tuned
- RickHaleParker
- Been thanked: 979 times
An electrical schematic is a logical representation of the physical connections and layout of an electric circuit.abscate wrote: 02 Mar 2019, 15:05 It is customary to accurately represent the switch function in an electrical diagram, so one of these isn’t right, tbd.
Accurately represent the switch Electrical functions - Yes
Accurately represent the switch Mechanical functions - Yes.
Accurately represent the switch Mechanical layout - No.
Active
Past
Past
Its interesting that the 'failure mode of the switch' exactly matches that of the switch mechanical layout in the electrical diagram - with the labelled switch functions of DOOR and ON reversed.
I doubt this is a failure deeper than this.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Steve -- As you may or may not recall, the driver door was changed on that car. I don't know if that had the potential to muck up the dome light?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- raivis_rsn
That doesn't matter if door lock actuator works as it should.E Showell wrote: 04 Mar 2019, 10:38 Steve -- As you may or may not recall, the driver door was changed on that car. I don't know if that had the potential to muck up the dome light?
Evan is on point here. If the connector was fubar, the door would close, the circuit would see the normally open connection, and the light would stay on in the DOOR position.
- Has thanked: 311 times
- Been thanked: 817 times
Junkyard! Or fellow MVS parts-hoarders. Replace the switch panel! This could have (possibly) been fixed by now ...
