P0171 System Running lean
zippy83
Year and Model: 2006 S40 2.4i
Post by zippy83 »
HI All,
I am back hammering at this issue. So I took some carb cleaner again and went to town. From different angles spraying around the intake manifold I noticed that the engine wants to stall during the heavy spray. Please see video below.
[youtube] [/youtube]
So my question would be, shouldn't the RPM go up when I spray the carb cleaner (co-worker of mine told me I should see increase in RPM) if there is a vacuum leak?
Once I took off the intake manifold I was able to identify that some of the carb cleaner got in. I have some gaskets on order but I was wondering about my question above..
Thanks
Zip
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Depends on the chemical composition of the carb cleaner you are using. Ether (starting fluid) is better for finding leaks in the intake system.
You video is not working, it will not play.
Active
Past
zippy83
Post by zippy83 »
I am not sure why it wont play on this site
here is the link
zippy83
Post by zippy83 »
I fixed the issue. Actually it was a bad gasket on the lower intake facing the cylinder head.
Off to the next issue... :)
KArthur1
Year and Model: 2010 S40i(non turbo)
Post by KArthur1 »
I have been chasing this same code. I build a DIY smoke generator. The only leak I found was where the emissions line plugs into the push-lock fitting. The fitting is right there on top of the intake between the mass air flow sensor and the firewall. The push-lock fitting is red. I sealed it with self-adhesive tape, but I still get the code from time to time.
This is the connection.
The bad gasket that you found, is it the one that you are spraying in the video? I think that is #5 intake (the one closest to the mass air flow sensor).
zippy83
Post by zippy83 »
The bad gasket that I found was on the air intake that faces the engine block. I was spraying the upper section which some of that cleaner got into the lower section and started to act up. The code went away and has not returned since.
In your case when the code comes back how long does it stay on?
KArthur1
Post by KArthur1 »
My code stays on until I clear it with my scanner. It will come back almost immediately. I am still trying to figure out where your leak was. Was it in # one or # two of this image.... or a different place? Can you point to it?
zippy83
Post by zippy83 »
Well in that case the code never goes away, the only reason it goes away is because you have cleared it manually but it comes back within minutes. You still have a leak somewhere.. Looking at the picture above mine was in the lower section. Your Air gets sucked in through the upper intake manifold (the big plastic peace) then goes through the lower intake manifold the (Iron made manifold) seen in this picture
That connects to your engine block (against the cylinder head) In order to remove that peace you will need to carefully move the fuel rail out of the way so you can re-install the new gasket, if that's what's bad. you will also need to remove the Air Box and to remove the air box easier without braking anything I had to remove the vacuum pump as well. From the picture below you will also notice that I have removed the battery as well..
Put is all back together and here are some torque specs
Intake manifold (lower section, against cylinder head): Torque to 19 Nm
Intake manifold (upper section): Torque to 10 Nm
Also worth mentioning is that your lean condition could also be caused by clogged PCV system. Have you inspected the PCV breather hose that connects to the crankcase from the Oil Trap? Also while you have the lower intake manifold off you can inspect couple hoses that are in the area that could also be a suspect. No 1 in the picture bellow.. inspect that elbow and make sure it is not cracked anywhere. No2 in the picture is the PCV breather hose that goes from the Oil Trap to the crank case.. (mine is out of the way) Make sure that on the OIL Trap it's tight. there is a small hose clam on there..
