What sizes vacuum tubing for a 1994 960?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
tmcmilli
Year and Model: 1994 Volvo 960
Has thanked: 3 times
Been thanked: 6 times
Post by tmcmilli »
I want to basically replace all of the vacuum tubing under the hood/bonnet and also that feeding to the inside of the car, where vacuum is used on the climate control system, with silicone tubing.
What sizes mostly do I need? I see silicone tubing in 10 foot lengths commonly available. But before I spend between say $15 and $20 per 10 foot roll, at least one roll for each size, I want to ensure I get what I need and especially no size that I do not need.
Also did Volvo use metric size tubing and do I need that for the best fit in some cases? I know how to convert SAE/Imperial to metric and I know a few sizes that are nearly identical between the 2 systems. I just thought if someone else out there had already done this job, I would like to benefit from the time you spent figuring it all out.
Thanks.
