2004 S60 2.5TAWD Lower Control Arm Hardware
StickyPocket
Year and Model: 2004 S60 2.5T AWD
Has thanked: 42 times
Been thanked: 6 times
Post by StickyPocket »
Hi all,
I'm replacing both LCAs and ball joints on my '04 S60, and was wondering if anyone had insight to the hardware required. I'm getting all Lemforder LCAs and Ball joints, and Febi steering stops:
1x https://www.fcpeuro.com/products/volvo- ... 9-30635231
1x https://www.fcpeuro.com/products/volvo- ... t-30635230
2x https://www.fcpeuro.com/products/volvo- ... s60-xc70-2
2x https://www.fcpeuro.com/products/volvo- ... r-31212191
Correct me if I'm wrong, but i need the following hardware:
2x https://www.fcpeuro.com/products/volvo- ... c70-985226
1x https://www.fcpeuro.com/products/volvo- ... olt-987456 for the right LCA
1x https://www.fcpeuro.com/products/volvo- ... 105-987455 for the left LCA
Which knuts do I need? Do they have to be from Volvo? If not, which size/metal should I get from the hardware store?
Thanks
2004 S60 2.5T AWD
Antoine240bk
Year and Model: XC70 2.5T-2006 - 4C
Has thanked: 12 times
Been thanked: 30 times
Post by Antoine240bk »
Looks like you're all set up! I would use genuine nuts and bolts.
You'll need
2x Self locking M14 nut 985660 for both LCA rear bolts
2 x M12 987455 for both LCA
2 x M12 987456 for both LCA
And possibly a tool to sit the ball joints properly
Volvo XC70 2.5 T AWD P2 B5254T2 - 12/2005 Four-C Previous : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -LPG - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
StickyPocket
Antoine240bk wrote: 10 Mar 2019, 14:58
You'll need
I need 2 of 987455 and 2 of 987456? So my assumptions in my post were wrong then? I thought I needed 4 bolts total: 2x 985226, and then the two horizontal ones looked like (from research on fcp and ipd) they were different sizes for left and right side. Do I need 2x 987456 for the RIGHT side, and 2x 987455 for the LEFT side? So it's 6 bolts total (2x 985226, 2x 987456, 2x 987455) ? And then do I need 6 nuts (985660) too?
Thanks
2004 S60 2.5T AWD
Antoine240bk
StickyPocket wrote: 10 Mar 2019, 15:26
You'll need
Thanks
This is what i needed for my XC70, guess it is the same with your S60
Yes, Bolts have different length on the front, 1x 987455 and 1x 987456 for one LCA. So 2 of those for each side. Bolts on the front screws on the lower control arm directly.
1 x M14 nut for the rear bolt 985226 in one LCA, you'll need two nuts.
Antoine240bk
If it happen that you plan to work the ball joint on the bench, take measurement of the shocks on the spindle knuckle to keep the camber right. AND take great care with the passenger axle, to not extent the axle.
StickyPocket
Thanks Antoine for your help and patience. Are you sure the two different horizontal bolts aren't for individual sides? (not one for front of each, one for back of each?) Here are some images from IPD, which i take to mean that both 987455 are for only the LEFT control arm, and both 987456 are only for the RIGHT control arm
Here's for 987455:
and for 987456:
2004 S60 2.5T AWD
Antoine240bk
You are totaly right!
Yes 987455 for the driver side and 987456 passenger side
I have done mine last june, could not remember it well, sorry!
To not confuse anyone:
2 x M12 987455 for driver side
2 x M12 987456 for passenger side
From my order in june
Been thanked: 4067 times
No hardware store stuff on these, please. You need the real hardware from Volvo.
StickyPocket
Thanks Antoine and abscate. Here's what I'm getting:
2004 S60 2.5T AWD
Have you got all the torque specs? On the V70, very similar suspension, the specs are written like
Torque to...xxx Nm
Then 90 degree tighten.
