So I assume the thing is beat and will order another one today. They are easy enough to replace. Does the cam error cause the lean running error or do I have yet another thing to track down?
cam solenoid and P0171 Bank 1 Lean
IslandV70
- Year and Model: 2005 V70 2.4
- Has thanked: 2 times
- Been thanked: 3 times
My car has been getting Cam Solenoid errors since I got it and also gets P0171. I took the solenoid off and cleaned it with Seafoam and an air gun with no changes
- RickHaleParker
- Been thanked: 979 times
Most likely you have another problem to track down.
P0171 = ECM-250A Long-term fuel trim.
Diagnostic trouble code (DTC) information ECM-250A
Condition
The engine control module (ECM) receives information from the heated oxygen sensor (HO2S) about the fuel/air mixture at different loads. The diagnostic trouble code (DTC) is stored if the engine control module (ECM) registers that the fuel/air mixture deviates too much from target lambda value, leaving the long-term trim in one of its limit positions.
Substitute value
None.
Possible source
Upper limit:
Condition
Substitute value
None.
Possible source
Upper limit:
- Damaged/Dirty mass air flow (MAF) sensor
Low fuel pressure
Air leakage.
High fuel pressure
Leaking injectors
Leaking evaporative emission system (EVAP)
Contaminated engine oil
Oil level too high.
- Malfunction indicator lamp (MIL) lit
Poor performance
May result in high fuel consumption.
Active
Past
Past
- RickHaleParker
Might as well. The MAF should be cleaned periodicity and it does not take much time.
Active
Past
Past
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
You night just have to dig in and clean the throttle body as well; as it gives off the lean fuel trim codes too.
- RickHaleParker
Security Torx Bits.
A lot A lot of times you can turn the Security Torx bolt with the right sized flat-head screwdriver. You wedge the flat-head screwdriver along the post and the ends of the blade into two of the points of the star then twist.
Active
Past
Past
EngineeringBloke
- Year and Model: 2006 2.5T S60
- Has thanked: 57 times
- Been thanked: 39 times
Or grip the edge of the screw with a pair of pliers and twist! I used this myself.
- 14 Replies
- 4241 Views
Last post by chitownV
- 5349 Views
Last post by mrbrian200
- 2513 Views
Last post by chrism
- 9194 Views
Last post by zippy83
- 10 Replies
- 4313 Views
Last post by RickHaleParker
