2003 V70 T5 Engine rebuild project
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
That's the original block...and a nice one too :-)
Been thanked: 4071 times
Will try to get some 2003 folks to post or pm me their VINS and engine numbers to help guide
Mountainman45
Year and Model: 01 V70XC
Has thanked: 2 times
Post by Mountainman45 »
Precopster, what makes it a nice block? What's different about it? And as far as the VINS go I appreciate the help
It's a nice one because it's a T5 2.3 block that handle higher boost pressures due to the slightly smaller bore and thicker cylinder walls.
If it were a 2.4 litre (2435cc) of the same era it would have thinner cylinder walls and not be as well suited to a custom tune where higher boost pressures are employed.
As already mentioned on this thread the engine of choice is the 2.5 litre with longer stroke but this would have to be modified to suit your car due to using two CVVTs instead of one.
Mountainman45
So boost-wise what am I getting stock? And what can I safely push it to without fear of blowing heads and other important stuff
That depends on.a lot of things..
1) Whether the wastegate is correctly adjusted (look on IPDs site in their tech tips for the correct procedure and specs for your engine
2) Condition and age of your head gasket
3) Condition/wear level of your piston rings
4) Condition of the valve seats on the head
5) Condition of your intercooler
6) Condition of the intercooler hoses (this is where silicon can be advantageous as it is generally stiffer under high boost than rubber)
7) Condition of the turbo
8) Current metal fatigue in the conrods (a weak point for these motors)
9) Condition of the main.and conrod bearings
10) Condition of cooling system
11) Condition of the lubrication system such as sump O rings, PCV system and oil pump
When new these motors had around 8-10psi
You’ve got some internet TCIP stuck on your 8 )
abscate wrote: 13 Mar 2019, 18:42
Went back in to edit it again. It won't clear Pfff!!
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
precopster wrote: 14 Mar 2019, 15:41 Went back in to edit it again. It won't clear Pfff!!
Because "8)" is the ASCII code for 8).
Active
Past
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2861 times
Been thanked: 1332 times
Post by matthew1 »
You can avoid this problem by checking "Disable smilies" in the Options tab beneath the editor.
Also -> Amazon link
