Getting a code 443 says purge control valve malfunction. I put in a brand new one from fcp still getting code.
Any thoughts?
Madness
2007 xc70 code 443 already replace purge control valve
volvomadness
- Year and Model: v70 2003
- Been thanked: 9 times
- RickHaleParker
- Been thanked: 980 times
P0443 = ECM-421B Canister purge (CP) valve. Signal missing
Diagnostic trouble code (DTC) information ECM-421B
Condition
The diagnostic trouble code (DTC) is stored if the engine control module (ECM) detects that there is no signal from the evaporative emission system (EVAP) valve.
The diagnostic trouble code (DTC) can be diagnosed when the ignition is switched on.
Substitute value
twin heated oxygen sensor (HO2S) control disabled.
Possible source
Malfunction indicator lamp (MIL) lit.
Condition
Substitute value
Possible source
- 1. Damaged evaporative emission system (EVAP) valve
2. Open-circuit in the signal cable
3. Contact resistance in the terminals
4. Open-circuit in the power cable.
Active
Past
Past
volvomadness
Thank you for the reply. I put a brand new purge control valve in the car and still getting the code.l
- RickHaleParker
Check the wiring, shorts/opens? Electrical Connector clean? Is it getting power? Ground good?volvomadness wrote: 12 Mar 2019, 17:08 Thank you for the reply. I put a brand new purge control valve in the car and still getting the code.l
Active
Past
Past
volvomadness
To test whether its getting power to the purge valve can I hook up a 12volt tester to the connection when the car is warm?
- Been thanked: 4071 times
Disconnect the purge valve electrical and look for 12 V on one pin to ground with ignition on.
volvomadness
I am almost sure there is a short somewhere. The connection is under the intake does anyone know if I trace the wires are they accessible how are they snaked?
Thanks Madness
Thanks Madness
You will spend hours fudging electrical stuff.
Look for 12 V at the purge valve , key on. The wires on Volvo disappear quick into well designed and insulated looms which rarely give trouble unless someone has messed with it.
Odds are 999/1000 it’s a simple missing 12 from a fuse , relay, or connector
volvomadness
Looked at all four fuse areas not one specifies a fuse, relay for purge valve solenoid or am I missing something.
Thanks Madness
Thanks Madness
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Here is a view of pertinent components. Item #6 is the SHUT OFF VALVE near canister -- rarely fails.
