Releasing fuel lines at pump 1998 v70awd How?
ka0ren
Year and Model: V70 1998 AWD
Has thanked: 2 times
Post by ka0ren »
Made an excellent tool, itlifts the plastic piece fully up, but I still cannot release the fuel lines
Even using leverage .
.. May tow it 135 miles to the shop
Vern
ka0ren
Post by ka0ren »
Going to try again later, tired now [ not to mention frustrated !]
Has thanked: 1609 times
Been thanked: 4065 times
Take a break, fresh arms and eyes in morning
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
ka0ren wrote: 16 Mar 2019, 15:00 Going to try again later, tired now [ not to mention frustrated !]
On the tool what is the width of the gap? Does the gap fit the pipe tight? Your trying to push a Ring on the bottom of the connector up. The Ring pushes the retainer holding the connector in place out of the way.
The Ring (Pink) slides up between the pipe and the Retainer (Red) pushing the Retainer away from the pipe.
It might help if you push down on the hose, up with the tool, then after pull on the hose and follow the connector with the tool.
The tool does need to be under the Ring.
Active
Past
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
I believe I've used needle nose pliers in a pinch.
ka0ren
Post by ka0ren »
Hi, Pump finally changed ! Had to use big prybar and new release tool. Two problems. Return fitting came apart and not able to re-assemble. Finally cut it off and used f I hose and clamps. No leaks and runs great ! Also gage now reads extremely WRONG. The plastic release for the return was worn thru and the metal retainer was smashed/bent beyond repair. Auto parts store had NOTHING that would fit.
THANKS ALL FOR YOUR SUPPORT !
bcfischer
Year and Model: 1999 V70xc
Has thanked: 14 times
Post by bcfischer »
Admittedly low tech, but after trying just about everything, I had success with a giveaway cheap metal paint can opener, as depicted below. I haven't tested it yet, but I'm pretty sure it can also be used to open bottles of beer :D Good to know when working on the Volvo fuel system....
Brian Fischer
Duluth, Minnesota, USA
late year 1999 V70XC (Chassis 587997)
RickHaleParker
bcfischer wrote: 18 Mar 2019, 09:25 I had success with a giveaway cheap metal paint can opener, as depicted below.
You confirmed my little pry bar method can work ... cool!
Active
Past
ka0ren
Post by ka0ren »
Little pry bar !!! NOT, had to use one 4 foot long.
Made 3 custom tools each one of heavier metal than the last.
None worked alone.
RickHaleParker
ka0ren wrote: 18 Mar 2019, 15:25 Little pry bar !!! NOT, had to use one 4 foot long.
None worked alone.
I have no idea why your's was so defiant. Did you piss it off? :wink:
Active
Past
