Temp Limits Roof Operation
pjmc480
Year and Model: 2006 c70 T5
Post by pjmc480 »
Tried to open the hard top today. Got this message "Temp Limits Roof Operation". Say's it's caused by power retractable hardtop mechanism overheating and to wait 5 minutes and try again. After waiting still not working and getting the same message. Any ideas? Is there a reset button anywhere?
Thanks
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
No reset button.
There is a temperature sensor in the electric motor. The sensor is connected to the
Convertible Roof Module (CRM). At high temperatures the Convertible Roof Module (CRM) limits
the functionality of the hydraulic pump in order to avoid damage to the system.
If you cannot open the roof when it is cool. Most likely the temperature sensor in the electric motor is defective or you got a wiring problem that is fooling the CRM into thinking the temperature sensor is yelling TOO Hot!.
I would have the car scanned with Volvo Vida to see if there are any CRM error codes.
Active
Past
pjmc480
Post by pjmc480 »
Thanks for the reply. I will get it scanned.
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
How cold was it in VA when you tried to open it? The top will close at much lower temps but stops opening if the temp sensor gets to around 32F. I'd have to look up the exact temp. The sensor is inside a foam sound enclosure for the motor in the bottom of the trunk. I would expect it to not change temps very quick so a really cold night might have it say NO well up into a day when it goes up 20 degrees.
RickHaleParker
jimmy57 wrote: 17 Mar 2019, 09:10 The top will close at much lower temps but stops opening if the temp sensor gets to around 32F.
The owners manual states the lower limit is 14° F (-10° C).
Active
Past
jimmy57
Post by jimmy57 »
I drove one for a while and it would not open at much below freezing. The training info is what you listed but they were known to not go down at close to freezing. I don't know if software was tweaked or temp sensors were not spot on accurate. Getting all the seals wet and the water freezing and then opening roof causing damage (warranty expense) to seals with less force than the pressure needed for relief valve to open would be the concern. When the top is stored in the boot there is little or no risk since the three parts have no seal contact stored on the perches provided there.
RickHaleParker
Could be that the hardware temperature have not recovered from the overnight low. It stand to reason that the temperature of the hardware is what matters not the Ambient temperature.
Active
Past
pjmc480
Post by pjmc480 »
Tried to open it the next day and it worked fine. Still going to get it scanned.
mmpeterson1850
Year and Model: C70 2012
Post by mmpeterson1850 »
Hi! Did you ever resolve this? My top is doing the same thing!
