Stripped Hex Stud on Ball Joint
joverman
Year and Model: 2006
Post by joverman »
Hey guys, I was working on replacing my ball joints today and everything was going smooth until I stripped the hex key spot on the stud for the passenger side ball joint.
I cannot tight the nut any further.
Any tips on how to get this tightened up or should I go to a shop?
Has thanked: 1609 times
Been thanked: 4064 times
Can you grab the stud with a Vice Grip (tm)
Get a good one, ie, not from Harbor Freight
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Were it me I would replace the ball joint now so it doesn't bite you in the future.
That said - abscate's idea works. If you have the space you can do some grinding to get a tool on it. You can try pounding a larger torx or allen into it. Sometimes putting pressure on the it with a jack from underneath will do it.
Regardless, when it comes up again you will have to fight what you did - so I would change it out now.
You can always grind off a fastener if there is still access. Once the torque goes up and the tapers get locked up you might not even need the counterhold
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Take a Torx Bit that a almost fits the Hex and drive it into the Hex. Back it off and replace the Ball Joint.
Active
Past
jimmy57
Been thanked: 322 times
Post by jimmy57 »
Jack the car up by that control arm so the control arm is pushing up with strut spring supported weight bearing down, this will often cause enough drag to stop the stud from spinning.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Small tip, if you can still remove the nut, remove it from there then use a steel mesh sponge to clean really well all the stud threads - so the nut can turn easily when tightening it. Then try the tips mentioned above, or more simply, replace the bj (Lemforder is the genuine one)
joverman
Post by joverman »
Thanks to all of you. I am going to give this a go later after work.
I do have a Lemforder Ball Joints btw.
joverman
Post by joverman »
Hey all, I couldn't get it any tighter or take it off. I'm going to have to take it to a shop.
Thank you for the help. I appreciate it.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
It was not hex, it was torx. That's why it stripped.
