- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Oil change and one ATF drain and fill for Ruby Red '04 XC70 (yesterday).
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
TheGageinator
- Year and Model: 2002 V70
- ndphotonl
- Year and Model: 2001 S80 2.4T
- Has thanked: 27 times
- Been thanked: 33 times
Hahaha that looks awesome! You need high/long travel suspension for this
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
FlickR images
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Did two videos about why it's important to clear the sunroof drains yearly and how to test the brake servo vacuum pump (leaking servo brake pedal seal)
- ndphotonl
Was finally able to change the rear engine mount on my S80. I was having trouble to undo the bottom 14mm bolt. Also mounted the polyurethane subframe inserts and am preparing for a retrofit projector project.
Volvo S80 2.4T Polyurethane Subframe Inserts by Andy Ramdin, on Flickr
Volvo S80 2.4T Retrofit Projector by Andy Ramdin, on Flickr
Volvo S80 2.4T Retrofit Projector by Andy Ramdin, on FlickrVolvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
FlickR images
- oragex
The small knobs to adjust the low beams on 2001-2004 (glass headlights)
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
Will be interested to hear your impressions of these and any improvements.
- Antoine240bk
- Year and Model: XC70 2.5T-2006 - 4C
- Has thanked: 12 times
- Been thanked: 30 times
On the XC70 i have mounted these poly inserts only on the front of the subframe with two strut bar inserts, quite pleased with it. I am waiting to do the rear ones or it might stay like this. This is for avoiding the increased road noise in the cabin.
On the V70 i had mounted the whole inserts kit with a transmission and top motor mount and the road noise and vibration was rally increased.
You can feel a slightly better steering feel, the car seemed solid. Those polyurethane thing are very good but if used jointly with a transmission and/or a top motor mount it is to the detriment of confort i think.
Volvo XC70 2.5 T AWD P2 B5254T2 - 12/2005 Four-C Previous : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -LPG - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
- ndphotonl
You describe my experience very well. I feel the difference in steering, turning is a lot tighter, the sloppyness is gone. I mounted all 4, but am thinking of trying to remove the rear 2, as I received a lot cabin vibrations. For now I will keep all 4 mounted, lets see if the polyurethane will set a bit.
The cabin vibrations are there when idling or driving with very low rpm (like when driving from a complete standstill). When cruising, you will wont notice a thing.
I also have all motormounts changed for new ones. The gearbox mount, the upper mount and the upper small ones have been replaced or reinforced with poly inserts as well.
Volvo S80 2.4T Polyurethane Upper Engine Stabilizer by Andy Ramdin, on Flickr
Volvo S80 2.4T Polyurethane Upper Engine Mount completed by Andy Ramdin, on Flickr
Volvo S80 2.4T New vs Old Gearbox mount by Andy Ramdin, on Flickr
Volvo S80 2.4T PU Gearbox mount by Andy Ramdin, on Flickr
Volvo S80 2.4T PU Gearbox mount by Andy Ramdin, on FlickrVolvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
FlickR images
- Antoine240bk
I went this route on the V70, lesson learned for the XC70! I think the transmission mount does a lot in vibrations.
I will mount the subframes inserts at the rear, but i will keep rubber for top and trans mount.
Happy spring day!
Happy spring day!
