To get the tripod out you have to grind down the staked ridges at the end of the inner joint bucket. I used a Dremel and a small grinding wheel. You might be able to use a small flat file but you need to careful with inner part of the bucket where the rollers slide.xHeart wrote: 23 Mar 2019, 11:47 A follow up:
Passenger side inner CV boot now leaks grease at the clamp. The boot looks fine, but grease looks and feels too thinned. Does the tripod fully comes out - is there a procedure?
2001 V70XC - Repairing front drive axle Topic is solved
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
- volvo inner cv joint staked end.jpg (82.38 KiB) Viewed 743 times
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Thank you!firstv70volvo wrote: 23 Mar 2019, 16:26
This pair of axle was donor from 2007 XC70 with 56,000 miles. The pair is in great condition at 100,000+ miles. The inner boot doesn't show any damage. I'll do a through clean up, refill with GKN grease, and finish with fresh crimp tie.
- Been thanked: 504 times
Hey xHeart,
Question re GKN Boot 31256231 you installed back in 2014.
I understand that these are thermoplastic (not rubber).
How many yr/miles have you had on these plastic boot?
Is Plastic boot holding up OK?
xHeart
The GKN boot was not a rubber like original, but it is flexible like rubber -- a silicon feel. The material has a finished look, deflective, and harder to pierce -- slips off. Recently, I refilled and clamped passenger side inner boot due to escaping grease -- my first time and poor crimping skills and choice of tool then.cn90 wrote: 29 May 2019, 23:22 Hey xHeart,
The pairs have above 50,000 miles with GKN boots and going strong.
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
Same reason I rebuilt both front axles last weekend. Only the inner passenger boot was leaking from the large clamp on the carrier. When removed it I find no damage to the rubber boot.xHeart wrote: 24 Mar 2019, 17:26
Just wonder how the grease got diluted?
For the new rubber boot I clamped it down tight without cracking it.
xHeart
I found rebuilding was best in my situation. I believe, cn90's write up suggested aging and extreme temps causes breakdown for grease to turn runny. The inner at the drive-axle (driver's side) appears to be holding. But I've rebuilt pair on the shelf incase.XC70Rider wrote: 05 Jun 2019, 23:28Same reason I rebuilt both front axles last weekend. Only the inner passenger boot was leaking from the large clamp on the carrier. When removed it I find no damage to the rubber boot.xHeart wrote: 24 Mar 2019, 17:26
The gas mileage continues to improve since the oil pan/crankcase project.
