Swapping Remote Module
mt98t5
Year and Model: 1998 S70 T5
Post by mt98t5 »
I'm in the process of parting out a 1998 V70r. Can I remove the remote module and install it into my 1998 S70? I didn't get a remote with the S70 and the trunk lock is different than the ignition so I am considering swapping out the ignition and other locks from the R too.
Has thanked: 312 times
Been thanked: 818 times
Yes, plug in the module and if you have a working remote from the V70 to go with it, it will work in the 98 S70. Programming the remotes requires a trip to the dealer on a 98.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
If your ‘98 S70 already has a remote module in the dash,
and you’re only missing the 9166200 fob, there should’t be
any reason to change the receiver module. Just get a hold
of a functional fob and have it programmed into the car.
Schmoyoho
Year and Model: S80 2007
Post by Schmoyoho »
erikv11 wrote: 23 Mar 2019, 23:12 Yes, plug in the module and if you have a working remote from the V70 to go with it, it will work in the 98 S70. Programming the remotes requires a trip to the dealer on a 98.
Bumping this... I've heard different stories on this. Is it really necessary to go to do the dealer to program remotes on a 1998 S70? Volvo has tried to do the procedure on an acquaintances' 98 S70 but they said it didn't work for what-ever reason.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
It isn't as elaborate a procedure as it is on the '99+ versions but you do need the Volvo Scan Tool or the equivalent to mate the remote on a '98. The 850s are totally DIY and the '99+ are a software download. The '98 is in between but I think my local shop charged me maybe $10.00 to do it on my daughter's old S70.
