Can Cylinder 5 Misfire / Clogged Injector Unclog?
AnyMajorDude
Year and Model: 2000 V70
Has thanked: 3 times
Post by AnyMajorDude »
2000 V70 with 150K miles has been diagnosed with a clogged injector and misfire in cyl 5.
Fuel injector cleaner has been added to the fuel since diagnosis. I do not have any codes or other metrics.
Can this resolve on its own by running the vehicle at idle or local driving? What are dangers of trying this?
Thanks in advance.
Been thanked: 4065 times
It’s so rare that I don’t think we have enough data to help here.
How sure are you on the diagnosis
0= crystal ball told you
1= Mechanic said “ it’s a clogged injector”
10. You have removed all th einjectors and tested the flow rates into graduated cylinders
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
as above, don't trust right away what mechanics say
may as well be a leaking valve seal, very common on these engines
greenellie
Year and Model: 1998 V70 GLT
Post by greenellie »
How are your vacuum lines? Also might be a wonky valve seal. Misfires around that mileage are more often caused by vacuum leaks. I had to replace a few until I finally found the leak that was causing my misfiring. I hope your car is doing better, get back to me! 8)
AnyMajorDude
I don't trust the local mechanic, that is why I am seeking forum advice. I will inquire if the vacuum lines and valve seals were considered. Idling and local driving... yes or no?
Has thanked: 311 times
Been thanked: 817 times
AnyMajorDude wrote: 26 Mar 2019, 10:22 2000 V70 with 150K miles has been diagnosed with a clogged injector and misfire in cyl 5.
Thanks in advance.
I wouldn't run more than a couple weeks on a clogged injector (if indeed, that is actually the problem). A clogged injector will make the cylinder run lean = excessive heat = burnt valves = thousand bucks. A week should be ok, depending on the demands on the car.
A good way to know if it is the injector is to swap them between two cylinders, see if the misfire follows the injector.
#5 misfire is often a leak in the intake manifold gasket.
