2000 V70 with 150K miles has been diagnosed with a clogged injector and misfire in cyl 5.
Fuel injector cleaner has been added to the fuel since diagnosis. I do not have any codes or other metrics.
Can this resolve on its own by running the vehicle at idle or local driving? What are dangers of trying this?
Thanks in advance.
Can Cylinder 5 Misfire / Clogged Injector Unclog?
AnyMajorDude
- Year and Model: 2000 V70
- Has thanked: 3 times
- Been thanked: 4068 times
It’s so rare that I don’t think we have enough data to help here.
How sure are you on the diagnosis
0= crystal ball told you
1= Mechanic said “ it’s a clogged injector”
10. You have removed all th einjectors and tested the flow rates into graduated cylinders
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
as above, don't trust right away what mechanics say
may as well be a leaking valve seal, very common on these engines
greenellie
- Year and Model: 1998 V70 GLT
How are your vacuum lines? Also might be a wonky valve seal. Misfires around that mileage are more often caused by vacuum leaks. I had to replace a few until I finally found the leak that was causing my misfiring. I hope your car is doing better, get back to me!
AnyMajorDude
I don't trust the local mechanic, that is why I am seeking forum advice. I will inquire if the vacuum lines and valve seals were considered. Idling and local driving... yes or no?
- Has thanked: 311 times
- Been thanked: 817 times
I wouldn't run more than a couple weeks on a clogged injector (if indeed, that is actually the problem). A clogged injector will make the cylinder run lean = excessive heat = burnt valves = thousand bucks. A week should be ok, depending on the demands on the car.AnyMajorDude wrote: 26 Mar 2019, 10:22 2000 V70 with 150K miles has been diagnosed with a clogged injector and misfire in cyl 5.
Thanks in advance.
A good way to know if it is the injector is to swap them between two cylinders, see if the misfire follows the injector.
#5 misfire is often a leak in the intake manifold gasket.
- 9 Replies
- 2869 Views
- 1420 Views
Last post by southofmotown
- 19 Replies
- 10254 Views
Last post by Barledge
- 2717 Views
Last post by erikv11
- 2514 Views
Last post by Ryanxr400
