87 volvo 240 dl dies after warm up no restart
Bdsexton06
Year and Model: 87 volvo 240 dl esta
Post by Bdsexton06 »
I have a 87 volvo 240 dl estate. Car runs perfectly for 20-30 min. Then dies suddenly but gas can be feathered to keep running. But engine misses and backfires only to die a few moments later. The can has had both fuel pumps replaced along with the wiring harness and fuse box in the past along with a long list of other parts and services from the pervious owner who was the orginal owner. I personally have rebuilt the distributor along with the hall effect sensor and the coil. Any help in the right direction is appreciated.
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
Bdsexton06 wrote: 19 Mar 2019, 11:56The can has had both fuel pumps replaced...
We do not refer to our Volvos as a "can."
So, hot wire the fuel pumps, and drive on James, but don't have an accident that ruptures fuel line.
Or, buy a new fuel pump relay....Or put a test bulb on fuse circuit feeding main fuel pump...so you can watch the bulb
dj_v70
Year and Model: v70 2003
Has thanked: 7 times
Been thanked: 23 times
Post by dj_v70 »
Shoot some starting fluid into manifold, does car start and run for a few seconds and die after that? If so, fuel issue. If so, do you hear fuel pump running? If not, jumper fuses 4 and 6, do you hear fuel pump now?
Bdsexton06
calm down "can" was a typo i love my volvo just as much as the next guy. finally got to do some investigating and found its a no spark issue. getting juice to the coil. and plugs and wires are new and tested good as well as the cap and rotor. also have replaced the hall effect sensor. there are three wires running off the sensor. does anyone have a wiring diagram that shows where the wires run to so i can trace the wire back.
93Regina
Post by 93Regina »
Bdsexton06 wrote: 26 Mar 2019, 06:18hall effect sensor.
Bdsexton06 wrote: 19 Mar 2019, 11:56wiring diagram that shows where the wires run to so i can trace the wire back.
93Regina
Post by 93Regina »
Bdsexton06
im thinking that it is my connector for my control module. its pretty well roached even for it having a newer (about 10 years old) wiring harness. ive been looking for a replacement online with no luck. anyone know where i can find a replacement or even a way to rig one. thanks for all the help so far.
