Heres the parts I ORDERED***
• OIL TRAP INLET HOSE
• OIL TRAP EXIT HOSE
• OIL TRAP
• ENGINE CRANKCASE BREATHER HOSE
( Oil seperator to engine block )
So these 4 PARTS all that is needed for my PCV SYSTEM??
PCV PARTS FOR my 02 Volvo S60 2.4L AWD TURBO
natural4reelz
- Year and Model: 02 VOLVO S60 TURBO 5
- Has thanked: 3 times
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
The intake manifold needs to be removed to reach the PCV oil trapper so you will need an intake manifold gasket. You will also need hose clamps. This kit contains those parts and the ones you listed.
https://www.fcpeuro.com/products/volvo- ... bo-v70t100
It's also smart to replace the banjo bolt and it's 2 washers
https://www.fcpeuro.com/products/volvo- ... vo-8653884
https://www.fcpeuro.com/products/coper- ... ring-11994 X2
You'll also want to replace the PCV nipple hose
https://www.fcpeuro.com/products/volvo- ... o-30731007
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
It's good that you included the PCV nipple hose, I think this is must have based on how brittle my old hose was when I did this job, it shattered into many piece when barely touch and you really need the Volvo part as a replacement.XC70Rider wrote: 23 Mar 2019, 15:17 The intake manifold needs to be removed to reach the PCV oil trapper so you will need an intake manifold gasket. You will also need hose clamps. This kit contains those parts and the ones you listed.
https://www.fcpeuro.com/products/volvo- ... 70-8653884
The only thing I might add is to use the latest designed banjo bolt that goes under the intake manifold. It has a check valve that helps prevent crankcase pressure under boost conditions. Part number 31325709, linked here
XC70Rider
Good catch. Forgot about the defective banjo bolt while searching for a different model. I installed the 31325709 banjo bolt on my XC70 last JAN after reading bad reviews of the other banjo bolts breaking up then causing engine damage.firstv70volvo wrote: 23 Mar 2019, 16:56
In case the OP doesn't catch onto this I edited my list with the 31325709 banjo bolt.
natural4reelz
The PCV NIPPLE #30731007 Will not fit my car it says....
I didnt see it listed in the kit either.... does that mean I dont have that part in my car???
XC70Rider
Trust me it'll fit. Other members will back me up.natural4reelz wrote: 27 Mar 2019, 02:40 The PCV NIPPLE #30731007 Will not fit my car it says....
They're just trying to urge us to buy the whole entire PCV hose that the nipple slides into.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Use the correct oeticker clamps on the hoses. I put instead a regular worm clamp and my hose slid off the engine block nipple and it was fun to reach and place it back. The oeticker clamps are a must when it comes to PCV hoses. A cheap oeticker pliers can be bought off Ebay and works fine for these small clamps https://www.ebay.com/itm/CV-Joint-Plier ... SwVv9cdvO5
natural4reelz
When i look at the PCV VENTILATION KIT its not even in the kit ..... And what are oetickers???
And what sizes and how many do i get??
Can u send me a FCPEURO LINK on where that PCV NIPPLE goes on
2002 VOLVO S60 2.4L “TURBO”// AWD
- firstv70volvo
At 8:20 into this video you'll see the installation of the PCV nipple hosenatural4reelz wrote: 27 Mar 2019, 07:58 When i look at the PCV VENTILATION KIT its not even in the kit ..... And what are oetickers???
EngineeringBloke
- Year and Model: 2006 2.5T S60
- Has thanked: 57 times
- Been thanked: 39 times
Oeticker pliers and clamps are special clamps to go around a hose and hold it in place. They are pulled tight by the pliers and then stay in place.
They do not have the diagonal cutouts and 'worm-screw' that a regular hose clamp uses. Those cutouts can wear at a hose and weaken it.
An Oeticker clamp has to be opened up when removing - a flat screwdriver can be used (see video at 9:15). I have not done this myself. The clamp cannot be reused.
- 1126 Views
Last post by Ben850
- 1842 Views
Last post by Vageloudakis
- 15 Replies
- 5843 Views
Last post by F250
- 906 Views
Last post by catchmeifucan652
- 30 Replies
- 9352 Views
Last post by Ben850
