01 v70 which engine hose? Has a leak
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
Hello so today I went out to get started on replacing the gear switch sensor (pnp?) because my reverse lights don't work. I was removing the air box when I noticed the metal hose going from the airbox to the exhaust. It has a few cracks in it which I think means it has a vacuum leak, right? I've been having issues with rough idling when starting the car after it sits there fore several hours. Can this hose be the issue with the idling? What is the name of the hose and what is the part number? I know it doesn't look like it's factory. BTW this is the NA version not the turbo. Pictures posted below with indicated hose circled for reference. Thank you!
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
Has thanked: 1611 times
Been thanked: 4072 times
It’s a warm air hose which helps keep the air temperature into the air cleaner constant.
It is not a source of vacuum leaks, it’s at ambient pressure at all times.
It’s condition is fine too, it can leak a bit without adverse effects, especially in temperate climates
Been thanked: 504 times
Post by cn90 »
1+,
For diagnosing air leak, do a smoke test.
