Harsh Engagement Into Reverse When Cold
zupta82
Year and Model: 1995 960
Post by zupta82 »
Hello, everyone, sorry I haven’t replied in a while. I took another look under my car and put it up on 4 jack stands. While someone was changing the gears back and fourth from Park to reverse, I noticed underneath the multi link suspension assembly there was a sharp twisting like movement of a rubber sandwiched bushing between the aluminum frame and rusty cast iron differential unit.
I guess there is a bunch of these anchorage rubber mounts that secure the fiberglass leaf spring they all seem to be chewed up from 190k miles. I would like to replace all of them but I can’t find any aftermarket or oem parts online, I sure hope they are not insanely expensive, it seems that the multi link 960 is so complex and expensive to fix sometimes.
Sorry for the long explanation I’ve also included some pictures of which anchorage bushing I’m describing
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
zupta82 wrote: 31 Mar 2019, 10:17anchorage bushing
Terminology....but engine and transmission mounts fail with time.
Transmission mount: 9434223 volvo
Engine mounts I'm not sure about, but maybe 3536226 volvo
These numbers can be used to Google for part replacement....Check Amazon's fitment first
zupta82
Post by zupta82 »
I replaced the trans mount(MTC brand) and both hydraulic plunger like mounts(Febi brand). Pictures I sent were of the rear differential They were both somewhat worn I figuired I replace them anyway
zupta82
Post by zupta82 »
I also did not see much change after the mounts
93Regina
Post by 93Regina »
zupta82 wrote: 31 Mar 2019, 10:17I can’t find any aftermarket or oem parts online,
I think this is for your model year....there is a left/right of this part...expand the part picture for more
Volvo 9140734
9140735
zupta82
Post by zupta82 »
Well, I looked around everywhere online and found a website called skandix I have enclosed some pictures below of the actual parts that I will need to rebuild most of the components for the rear fiberglass spring. Unfortunately, I can’t find these parts available anywhere as they are discontinued. I also looked around at some of these genuine Volvo part websites and they want like 145.00 for one rubber bushing, which is insane!! There has got be a a way I could fabricate something out of a universal leaf spring isolator pad??? I hope I won’t end up junking this car!!
zupta82
Post by zupta82 »
zupta82 wrote: 01 Apr 2019, 07:21 Well, I looked around everywhere online and found a website called skandix I have enclosed some pictures below of the actual parts that I will need to rebuild most of the components for the rear fiberglass spring. Unfortunately, I can’t find these parts available anywhere as they are discontinued. I also looked around at some of these genuine Volvo part websites and they want like 145.00 for one rubber bushing, which is insane!! There has got be a a way I could fabricate something out of a universal leaf spring isolator pad??? I hope I won’t end up junking this car!!
88D8A1AD-D694-419C-8B56-0B01670AA670.jpeg0DD763EA-E194-457A-8F69-2A67109ECEE5.jpeg6675A88A-FC0C-4525-A817-40133DE1ECDC.jpeg
93Regina
Post by 93Regina »
zupta82 wrote: 01 Apr 2019, 07:21There has got be a a way I could fabricate something out of a universal leaf spring isolator pad?
I'm ignorant on this topic, but I thought there was a way to make a traditional rear end setup.
I would have see your rear-end setup on a lift to examine.
I recall a Craigslist ad, where person suggested a fixed rear-end setup could be done.
93Regina
Post by 93Regina »
zupta82 wrote: 01 Apr 2019, 07:21I can’t find these parts available anywhere as they are discontinued.
Do you have specific part numbers...with Google, I might be able to find them.
zupta82
Post by zupta82 »
I called my local Volvo dealer and I am still waiting for them to contact Volvo directly as they say they might be discontinued or back ordered.
Here are the part numbers
(Bushings closest to wheels) 6819182
(Middle of axle) 6819183
(Near driveshaft yoke at base of differential)6843603
I guess this should cover all the chewed up rubber pieces on the rear suspension??
