2006 XC90 2.5 FWD-front drivers side growl
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
Seeing as you're still banging your head on this after some time and an expensive part or two later, I'm going to say it again...
At this point I'd say you're either looking at differential noise (transmission) or a rear wheel bearing.
In the following video while making the video the guy is convinced it's front end diff noise. If you look at the comments it turned out to be a REAR wheel bearing. It's a Toyota truck, not a Volvo. But the point is that the noise as localized from inside the vehicle does not necessarily mean the noise is coming from from where you seem to hear it or even feel it. I've been through this with my sister's 2003 XC90. Driving the car you might have sworn the front left wheel bearing or angle gear/transmission was about to blow up. It was the right rear wheel bearing. Sitting in the back seats or front passenger you'd only feel it a little and barely hear it.
Youtube Video: Toyota rear wheel bearing mistaken as front differential noise
Please take a look at the rear end (wheel bearings, drive shaft, rear differential) before throwing more money at the front.
aaron1611
Year and Model: 2006 XC90 V8
Has thanked: 2 times
Been thanked: 5 times
Post by aaron1611 »
ok, thank you. Watched the video and I definitely hear the whoomp whoomp sound when on the highway so I'll take your advice and get someone in the back to confirm noise is or isn't coming from the rear and post back.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
91 240 Wagon 5 speed 211K daughters daily driver sold
2013 XC90 wife's daily driver 201K
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
Volvo's that were driven and flipped:
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
Been thanked: 504 times
Post by cn90 »
Jack up each wheel and spin it to diagnose bearing noise.
aaron1611
Post by aaron1611 »
well, I did the rear wheels already and I didn't feel or hear anything after spinning them. I haven't done the front passenger side yet which is probably what I'll do after confirming if any sound is actually coming from the rear.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
mrbrian200
Wheel bearings sometimes will not have physical play and only make noise when there's weight on them. ie-they'll seem fine spinning by hand with the vehicle raised off the ground.
aaron1611
Post by aaron1611 »
I took a test drive with my wife in the back with her ears to the floor and there isn't any sound coming from the back. She rode as a passenger and could hear it but not as clear as I can. I then let her drive and then she could hear it very well. I will say that it is much less of noise sitting in the passenger seat but I can still feel it coming thru the floor with my feet. I will jack up the front this afternoon and spin the front passenger wheel.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
dj_v70
Year and Model: v70 2003
Been thanked: 23 times
Post by dj_v70 »
Consider buying a set of chassis ears.
aaron1611
Post by aaron1611 »
I'll see if any local parts stores has one available to rent. Thanks for the suggestion.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
aaron1611
Post by aaron1611 »
While I was out of town this week my wife dropped the Volvo off to have the front alignment performed but the shop was unable to move forward due to necessary repairs needed to be done first. Front right axle shaft, inner left tie rod and both front lower control arms. It's quite possible that these repairs will fix the sounds emanating from the front. I've yet to find a rental chassis ears tool but will keep looking. Interestingly, they said nothing about front wheel bearing hub needing to be replaced.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
Been thanked: 4071 times
Growl louder on swerve right.......bad left bearing
Growl louder swerve left.......bad right bearing
It’s quite pronounced an effect. Once they get noisy they last another 10-15000 miles or so , then get really noisy, then I don’t know what happens but I bet it’s ugly.
If it isn’t changing on loading, it’s something else
I’ve removed noisy wheel hubs and they bench feel like a new one, by the way.
