2005 XC70 headlight upgrade
EamonnMR
Year and Model: 2005 XC70
Post by EamonnMR »
So I'm finding the brightness of the headlights a bit lackluster. Can't see far enough ahead of me at night, and there are deer and such around here. I know there where better headlights as an option, Xenon or some such, can those be swapped right in? Or has anyone found LED headlights that are compatible and brighter?
Been thanked: 4065 times
Definitely check your reflectors to see if they are shiny and bright, they do tend to oxidise and then the lights get sad and gloomy.
New Volvo ones about $400 a side here (Ouch)
TYC or Valeo are about half that - Ill bet VALEO make them for Volvo
31276832, 30648217, 30698838 Right
31276831, 30648216, 30698837 Left
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
OE are Valeo afaik.
I agree check the reflectors and since it's an 05 the condition of the plastic lens. Stock halogens aren't super but they are pretty decent.
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 57 times
Been thanked: 39 times
Post by EngineeringBloke »
You can recondition the plastic over the headlights with a kit, but they tend to revert fairly quickly. Perhaps a clear coat on top, but I have not tried it. On my list to do!
veektor
Year and Model: 2008 S60
Has thanked: 3 times
Been thanked: 4 times
Post by veektor »
The lenses on my '08 are hazy. Whenever I see the earlier years of P2 cars in the junkyard, I feel the impulse to get the older headlights with glass lenses, and attempt to retrofit them on mine. I haven't bothered because I have a strong suspicion they wouldn't fit, and there is not a single DIY post about such retrofit. Still, doesn't stop my from fantasizing about those gloriously crystal clear lenses.
Rattnalle
Post by Rattnalle »
The other way around works so I don't see why it shouldn't you'd just have to create the adapter wiring yourself, reversing the wires for a plastic headlight on an older car.
Been thanked: 504 times
Post by cn90 »
If the plastic cover gets hazy, search "bimmerfest E39 forum" for tricks on how to do wet sanding to restore the plastic to factory clarity.
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
veektor wrote: 01 Apr 2019, 13:43 The lenses on my '08 are hazy. Whenever I see the earlier years of P2 cars in the junkyard, I feel the impulse to get the older headlights with glass lenses, and attempt to retrofit them on mine. I haven't bothered because I have a strong suspicion they wouldn't fit, and there is not a single DIY post about such retrofit. Still, doesn't stop my from fantasizing about those gloriously crystal clear lenses.
Do only the 2000 & 2001 have glass lenses? I've been searching for them also. The adaptive bulbs have slightly melted the inside of my plastic lenses.
Rattnalle
Post by Rattnalle »
2004 has glass. 2005 and on plastic.
XC70Rider
Post by XC70Rider »
Rattnalle wrote: 03 Apr 2019, 22:36 2004 has glass. 2005 and on plastic.
There's a 2004 S60 AWD in a junk yard 6 miles south of me. When I was there yesterday they quoted me only $25 for each headlight. I'll stop over and snatch them today. :D
I was peaking at the driveshaft and the rear flange on that 2004 S60 AWD. The driveshaft was 2" shorter than the one on my 2007 XC70 and the flange didn't have the rubber damper inside.
