V70 xc 2.4 turbo wont go over 3000rmp.....gets up to speed just slowly
V70xc1999
- Year and Model: 1999 v70 c.f. 2.4 Tu
Flow is good (no cat)and yes sounds like maybe coming from j hose at breather box.....its a loud wissle after I press on peddle starts at like 2500 some as my max rpm at the moment....I may have also found a leak in gas line.....only when pressure builds
The PEMs give up in 10-15 years and will first give you a miss at speed , then no start
You have to diagnose the root cause, not throw parts by symptom. Check fuel pressure with gauge. Monitor while driving
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
I don't think our year has a PEM. Thought we only had the fuel pump relay.
V70xc1999
Thanks had me boggeled when I googled it....me and my 13 yr. Old have it torn aprt now....found a loos clamp I think comming of breather box....gonna install new I hose comming of brether box.....also some one said there is many things that go qrong with the etm.....i imstalled contactless poilsition sensor on original..no change...so installed a used one and was doing same thing....no change....what are the odds of them both haveing same issue? Wont go over 3000rpm and it gets up to speed and shifts....
- 2514 Views
Last post by RickHaleParker
- 638 Views
Last post by ogatrulle
- 19 Replies
- 6594 Views
Last post by hiroku
- 40 Replies
- 7154 Views
Last post by Rocket999
- 674 Views
Last post by Ozark Lee
