There seems to be an issue with the electronic controls of my driver seat, where it will move forward/back, up/down...but the seat back will not move forward/back. I initially heard like a grrr noise, but when I got home, I noticed that the motor seems to be working fine. Does anyone have any experience with this. Not sure what is involved and why the motor is working, but nothing is happening. Appreciate any help!
Thank you.
1995 850 T-5R Driver Seat Back Stuck
- RickHaleParker
- Been thanked: 978 times
The mechanical drive cable plastic jackets expands with age and pulls the metal cable out of the motor or the gear boxes.
You can replace the cable or shorten the plastic jacket.
New cables are ~$60.00 each .
To shorten the plastic jacket:
1. Measure the play in the metal cable.
2. Pull the metal end cap off the plastic jacket .
3. Shorten the plastic jacket by the amount of measured play.
4. Reinstall the metal end cap.
Active
Past
Past
I looked at a video, and it looks like to do the repair, it takes a toll on the upholstery, where you have to zip tie it back? Is there a way around all of this to cause minimal damage? The seats are in perfect condition.
Also, how long to do the repair? Looks like both seats don’t go back.
Thank you!!
Thank you!!
- Has thanked: 2199 times
It is a little time consuming but not hard. I use hog rings and hog ring pliers to do the repairs. Not had any real issues with it.
It’s not rocket surgery. See my thread on reskinning a P80 seat, 4 hours to remove and replace 4 parts , so an hour to do one, roughly.
- 2028 Views
Last post by 850forum
- 823 Views
Last post by rspi
- 9 Replies
- 2216 Views
Last post by E Showell
- 1882 Views
Last post by CIK7
- 1720 Views
Last post by darrylrobert
