2004 S60 - Jumping another car Topic is solved
patb94
- Year and Model: 2004 S60
How would you jump another car from the engine compartment? The manual speaks to how one would jump your car (the Volvo) using the engine compartment but but doesn't provide guidance on jumping another persons car. Is there a negative terminal in the engine compartment?
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
There's a bunch of ground connectors on the inside of the fender close to the positive terminal under the hood. So it's the same as getting a jump start. At least that's how I've done it a few times.
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
With our remotely located batteries you use the terminals under the hood rather than clamping directly onto the battery posts.
It's wise to pre-check if your jumper cables' clamps fit into the shrouding of the positive connection AND bite solidly.
The available negatives aren't large so it's smart to check for fit. The top engine mount might be too big for some cheap clamps' jaws.
patb94
Thank you all for the replies
From what i am gathering, one can ground the negative to the chassis of the car instead of the negative on the battery when using the Volvo to jump another car. Is this accurate?
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
I removed the plastic cover off the battery in the trunk and stashed it in the basement. Everything I have in the spare tire area either fits inside the spare/locked down, or is plastic that wouldn't cause a short. I don't jump other cars very often. But when I have people are like 'oh nice the battery is in the trunk'.
- Rattnalle
Yes.patb94 wrote: 09 Apr 2019, 06:07 Thank you all for the replies
- 34 Replies
- 4288 Views
- 1794 Views
Last post by precopster
- 21 Replies
- 2420 Views
- 16 Replies
- 2937 Views
Last post by Ozark Lee
- 2537 Views
Last post by highmiles
