I know this is a common problem, but my searches are not turning up good results.
The other day, I smelled a faint but distinct electrical burning smell. I was hoping it was coming from some truck I was following, but now I have no air being blown through the vents when I select ac/heat. This the more advanced (and complicated) system where you select a temperature and it regulates. The fan/blower speed switch is the slider that begins at AUTO on the left and then goes to manually variable speeds. So...
I'm thinking it is the switch itself since this sort of switch often goes bad. I'm hoping it's not the blower itself.
Thinking about taking a trip up to the u-pull-it yard to see what's there. Has anyone ever successfully repaired or replaced this slider switch? Is there some resistor that finally gave up the ghost and smoked itself? Fusible link?
What's the 411 on this?
1999 S70 Auto-Temp Blower not working. Switch?
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
All U.S. market models.
All running and on the road.
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
You should be able to get codes from the ECC.
Does the fan/heat work when you choose temps/speed manually? When you turn AC off?
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Eddystone
No blower activity at all regardless of settings selected, manual or auto. Car has 148k miles on the odometer. I get forced air through vents when moving and the switches that control where the air comes out (face, defrost, floor) all function properly. It must be either the switch (with Auto and manually variable speeds) or the blower itself.
I am planning to take this car off the road in a week or so to replace the heater core and fix the dashboard noises (been there before with another car) but I'm not pulling it apart before then.
Just looking for background info at this point.
Anyone know if this auto AC module is used in other Volvo models that might be in the Pick-N-Pull yard?
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
99.9% of the time, the motor bearings wear and
it begins using more power to continue turning.
That in turn puts too high a load on the electronic
“resistor” between the motor and the ECC control
unit. You may just need a new motor, but both of
these units could require replacement.
It’s very unlikely that there are any bad parts like
switches or sliders in the ECC controller itself.
Sommerfeldt
BEJinFjk is right - no need to make things more complicated than they are. Yank out the blower - that’s a 10 minute job - and put 12V on it to see if it moves. I’ve had to replace blowers on 2 Volvo’s, one of them twice, and never had to touch the ECC.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Has thanked: 1613 times
- Been thanked: 4075 times
That switch carries no current, it just sends a small signal to the ECC controller. As above, it’s probably fan motor or the mosfet power pack.
- Eddystone
Thanks to everyone for the information. My car is being inspected in a few days, so I am going to put this off for a week. I'm going to be pulling the dash to sort out all the noises (been there on my other car with success) and replace the heater core. Might as well do all of this at one shot.
When we speak of the MOSFETs or the power pack, I am assuming that we mean the resistor assembly that also senses temperature. I replaced one of those in a BMW, and they called it a hedgehog because of its appearance.
Yeah that’s the one. It lives down in the climate unit, just next to the blower.
I think I took pictures in this thread
viewtopic.php?f=1&t=62386&p=320751&hili ... t5#p320751
markone
- Year and Model: 2007 V70
- Has thanked: 21 times
- Been thanked: 14 times
I don't wish to hijack this thread. However, I am having some similar symptoms on my 1998 v70. Fan motor is intermittent. Slider switch has no effect on fan motor most of the time. Swapped ECC unit with one from Erie Vo-Vo, but no improvement. Any thoughts?
2006 V70 NA/manual trans, 165k
2007 V70, NA/manual trans, 143k miles
2023 BMW X1, 29k miles
2018 Jeep Grand Cherokee LTD, 91k miles
2007 Malibu Response LXi, Ebony/white, 340 hp, 395 hours
1997 850 Sedan NA, manual trans, sold at 330k miles
1998 V70, NA/manual trans, sold at 365k miles
- 997 Views
Last post by jimmy57
- 1277 Views
Last post by Ozark Lee
- 1116 Views
Last post by KrazyKrusty
- 632 Views
- 1698 Views
Last post by paredown
