2004 XC70 MPG on 91 Octane (US)
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Rattnalle wrote: 09 Apr 2019, 10:10 Over here we avoid lights and mostly use roundabouts instead.
They are doing more and more roundabouts in Kansas but, they keep making the center hub too big for our extra long tractor-trailers. In Kansas the legal length limit for a trailer is 59.5 feet (18.137 meter). Guys pulling 53 footers have trouble getting around.
Active
Past
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
RickHaleParker wrote: 09 Apr 2019, 10:51
Ours usually have a brim paved with stone around the centre. Perfectly possible to drive on but uncomfortable in a regular car. Then you both have to slow down and large vehicles can pass. Either that or a diameter that's large enough for vehicles to pass.
Regular EU truck and trailer combo is 18,5 m. Sweden generally allows 25,25 m combos everywhere and up to almost 40 in some cases with three trailers I think. Mostly timber lorries. Then you've got excavator carriages and other long things to take into account.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Highway only was 30.5 Avg MPG over about 20+ miles at about 70 mph, or slightly less, in the wind shadow of a commuter bus.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Has thanked: 1611 times
Been thanked: 4075 times
I get 32 mpg out of the NA FWD routinely and 35 mpg if I drive for mileage. That’s ridulous mpg for such a luxury ride.
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
I've found that dialing in the wheel alignment affects both city and highway mileage, but city more. If it's off a little highway might drop 1-2 mpg, which isn't that much, but it'll become a real pig in the city as instead of coasting half or more of the time with your foot off the pedal you never take your foot off the gas unless you're braking to a stop. I drive mine in Chicago downtown area sometimes in rush hour fairly often and this is my experience as I've been tweaking the alignment/suspension over the last few years since I bought it.
Edit: adding a little more personal experience with regard to rolling resistance due to wheel alignment in city driving. Without touching the gas pedal on flat level pavement, taking your foot off the brake the car should roll up to at least 10 mph on its own given a little time. If alignment is off, even by a little bit, you simply won't get up there without touching the gas pedal. That's on a FWD. AWD cars would be different and might not go much faster than a creep/walking pace at idle.
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 9 times
Been thanked: 22 times
Post by prwood »
My 2001 V70 2.4T automatic transmission gets about 14mpg city, 27-30mpg highway, depending on cargo load. Keep tires inflated to 38psi at all times, will bump up to 40 or 42 if carrying a super heavy load (learned from experience). I try to avoid using the turbo boost unless needed. 87 octane gas. Tracked in the Fuelly app at each fillup since my car doesn't have a built-in MPG indicator. I wish the city mpg was better, but I'm pretty happy with the highway mpg.
Cars I've owned:
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
matthew1 wrote: 09 Apr 2019, 10:06
oragex wrote: 09 Apr 2019, 09:30 It also comes down to the engine running condition (sensors, etc). I'm rather jealous when I read about people getting 20mpg in city driving, I get rather 15mpg.
Well that's the problem I have with city, or should I say "City". New suburbs tend to have long stretches of timed lights, like the new Denver suburbs to the far north or far south of the city. Good for MPG. Downtown Seattle for instance is the opposite. Traffic, monster hills, gridlock. But that's "City" also. They're really not comparable.
I'm thinking the same. The engine consumes the most in the first moments when acceleration from a light/stop, the more the stops, the worse the mpg Not a scientific measurement but it shows here www.youtube.com/watch?v=50lev2aUWHw
E Showell
Post by E Showell »
31.1 highway this a.m. Inflated a rear tire. Speed between 60-70, no commuter bus.
'95 855 auto (sold)
Rattnalle
Post by Rattnalle »
I've got an average of 28 mpg based on all refuelings since I bought the car almost 50' miles ago. Probably something like 40/40/20 motorway(incl Autobahn at high speed)/regular rural roads/city. Average speed in the trip computer usually ends up at 40 or so over time.
I wonder if all that money saved on gas goes through your mind as that Nissan Rogue on I287 crushes your Prius like a tin can?
