IPD sale Volvo Parts
Did you know? 🤔
Buying a C70 2008 with Head gasket problem or one with transmission problem
RickHaleParker
Has thanked: 3 times
Been thanked: 304 times
United States of America
RickHaleParker
Re: Buying a C70 2008 with Head gasket problem or one with transmission problem
Post by RickHaleParker » Wed Apr 10, 2019 12:50 pm
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
tango_1000
Year and Model: c70 2004
Has thanked: 6 times
Been thanked: 0
Argentina
tango_1000
Post by tango_1000 » Wed Apr 10, 2019 1:45 pm
Thanks, but this look more like previous years, mine now is a 2007. I think I will just take air filter or everything easy on the top. The car is beautiful...
Has thanked: 185 times
Been thanked: 574 times
Trinidad & Tobago
Post by abscate » Wed Apr 10, 2019 3:06 pm
Go to Volvo user manual online and check the manual
The trend in cars is to eliminate the dipsticks for sensors - a practice I abhor.
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
RickHaleParker
RickHaleParker
Post by RickHaleParker » Wed Apr 10, 2019 3:40 pm
Transmission dipstick Volvo part number 30713102.
Fits:
Volvo C30 2.4l 5 cylinder 2007, 2008, 2009, 2010, 2011
Volvo C30 2.5l 5 cylinder Turbo 2007, 2008, 2009, 2010, 2011, 2012, 2013
Volvo C70 2.4l 5 cylinder 2006, 2007
Volvo C70 2.5l 5 cylinder Turbo 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013
Volvo S40 2.4l 5 cylinder 2004, 2005, 2006, 2007, 2008, 2009, 2010
Volvo S40 2.5l 5 cylinder Turbo 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012
Volvo V50 2.4l 5 cylinder 2005, 2006, 2007, 2008, 2009, 2010
Volvo V50 2.5l 5 cylinder Turbo 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012
On my '98 C70, I got to push a intake air hose aside to see the transmission dipstick from above.
You might try sticking your head under the car and look up to locate it.
I think the newer ones have a shorter dipstick tube, look way down deep from the top.
These users thanked the author RickHaleParker for the post:
tango_1000
Year and Model: Lots
Has thanked: 4 times
Been thanked: 93 times
Australia
Post by precopster » Wed Apr 10, 2019 4:47 pm
They are awfully stumpy small dipsticks and totally different in location to a 98 S/V/C 70
The lower radiator hose needs to be pushed aside to view it from the top. Wear gloves as it gets hot down there!!
These users thanked the author precopster for the post:
tango_1000
Current cars:2002 XC70, 2006 Ssangyong Rodius (Stavic), 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
tango_1000
Been thanked: 0
Argentina
tango_1000
Post by tango_1000 » Thu May 30, 2019 4:31 pm
I like to thank everyone here for the help and interest. And continuing with this post. I didnt buy the head gasket problem car. I bought the C70 2007 with a transmission problem. Trying to fix that. The transmission will hit hard at some gears so , as someone advice here I put new fluid. I did a flush and of course use the mobil1 3309, that by the way I found it at 5 bucks at summit. So today I was very happy because first and reverse didn't feel a thing, very smooth, but when I got to 50...miles per hour and more than 2500 rpm that's when the car jumps and go to save mode (?) I think that's what its called. Then will work only on 2nd and 4th gear.
So it feels the gears are ok if they work with fluid. Again, the problem was and still is when go over 52 or 53 miles per hour.
I also like to add that I took it to a mechanic (friend) cause it had a leak on the rear main seal and torque convertor seal.
If this is a solenoid problem , can I change the valve body???
Thanks to everyone
