Continuously Controlled Chassis Concept (CCCC, Four-C or 4C)Tex69 wrote: 10 Apr 2019, 09:21 What is the 4C suspension? Is that the computer controlled suspension that allows for the three modes?
Yes it has three modes, Comfort, Sport and Advanced.
this is quoted
Right, that's what I had been doing. When going to use that function, I was getting that peculiar message. Seems to have stopped now.EngineeringBloke wrote: 10 Apr 2019, 20:02 To use quotes, click on the double quote icon and you will see
Square bracket, "quote", close square bracket, and then Square bracket, "/quote", close square bracket
Put what you want quoted in the middle between the first close square bracket, and and the second start square bracket.
Example with extra spaces inserted around word "quote":
[ quote ]this is quoted[ /quote ]
this is quoted
Comfort, sport. Advanced, and poor.erikv11 wrote: 10 Apr 2019, 17:53 There is a secret code hidden in the 4C name, hold down the shift key on your keyboard while you type 4C ...
MDK wrote: 10 Apr 2019, 09:15 Hey Tex 69...MDK here. If you could send us a photo of the wagon from the side.. that would help. Some one probably put lowering springs on it using the factory struts. I have an 04 R car and I just stripped out the 4 c suspension... good riddance. I utilized the factory struts and springs from a 07 S60 AWD... I have the code prompt on the dash... but I don't care. MDK
Oops. Forgot you wrote this. Here are a few more.MDK wrote: 10 Apr 2019, 15:40 Hey tex... I meant take a photo of the entire wagon... the whole enchilada... from the side. MDK
