IPD sale Volvo Parts
Did you know? 🤔
13t boost questions
Gmstewart22
Year and Model: 2000 v70 GLT, 850-T5
Has thanked: 11 times
Been thanked: 0
United States of America
Gmstewart22
13t boost questions
Post by Gmstewart22 » Fri Apr 12, 2019 11:21 pm
Turbo technitions I need your input, I have a 98 v70 awd that is my new project car. I am curious if I get a custom tune what is the max boost I can efficiently run this turbo up to with stock setup and what kind of power gains can I expect?
2000 v70 GLT
1997 v70 AWD lpt
1997 v70 AWD lpt "rally rig"
1995 850 T5
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 1 time
Been thanked: 20 times
tardcart
Re: 13t boost questions
Post by tardcart » Sat Apr 13, 2019 6:57 am
That should be a 15t in there? Is it a low pressure turbo 2.4? or 2.3T? If its the 2.4 better leave it alone.
Sommerfeldt
Year and Model: 1996 850 T5
Has thanked: 42 times
Been thanked: 25 times
Norway
Sommerfeldt
Post by Sommerfeldt » Sat Apr 13, 2019 8:30 am
The ‘98 should have a 13G or 16T.
- S
'96 855 T5, R bumper and spoiler, Koni Yellows & blue H&R springs all 'round.
Has thanked: 6 times
Been thanked: 128 times
Canada
Post by scot850 » Sat Apr 13, 2019 11:59 am
V70 AWD/XC have a 13T and c. 193 bhp. These are good turbos as standard as they have a fair amount of torque low down in the rev band. Surprised a few cars with my 98 XC at the lights!
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
Gmstewart22
Been thanked: 0
Gmstewart22
Post by Gmstewart22 » Sat Apr 13, 2019 2:06 pm
I'm about positive it's the 2.4 with a 13T, I have 3 of them and would like to get a tune and run about 10# boost run the cutoff at about 11.5 psi, these lpt engines are getting more and more popular as mild build projects.
I will be rebuilding this block eventually with stouter internals long term I want a sequential setup on this car. Fyi this is not my daily I drive a silverado as a daily. I want to make this car a little snappier while I'm rebuilding the donet block!
2000 v70 GLT
1997 v70 AWD lpt
1995 850 T5
Gmstewart22
Been thanked: 0
Gmstewart22
Post by Gmstewart22 » Sat Apr 13, 2019 2:10 pm
*doner* block
2000 v70 GLT
1997 v70 AWD lpt
1995 850 T5
Has thanked: 178 times
Been thanked: 541 times
Trinidad & Tobago
Post by abscate » Sat Apr 13, 2019 2:52 pm
Check out the Speed forum below ...apologies for missing this earlier but Im a stock guy...
https://www.matthewsvolvosite.com/forum ... =5&t=86785
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
tardcart
Has thanked: 1 time
tardcart
Post by tardcart » Sat Apr 13, 2019 5:30 pm
The td04-13 doesnt make a lot of volume so it sort of gets swallowed up at high rpm and open throttle with a 2.4 later engine. I dont think it would make more than 5 psi at full rpm and throttle if even. You can find out by disconnecting and plugging the wastegate vac. line but go easy at low rpm. at low rpm it could make 15lbs and maby bend a rod. You dont really need a tune unless you are going to increase the turbo size. there is no harm in an uncontrolled small turbo, just dont lend the car out and feather the throttle from a stop.
there are specs out there for volume of air per psi for turbos, and you can figure the volume of air digested by 2.4 liter engines at a rpm corrected by added pressure.
Gmstewart22
Been thanked: 0
Gmstewart22
Post by Gmstewart22 » Sat Apr 13, 2019 5:36 pm
I think without a tune the computer registers over boost and compensates with fuel then the car falls on its face at least that's how my wife's 2000 lpt works anything over I think 6 or 7 psi it cuts fuel and falls on its face and recovers again a few seconds later. Were the pre 2000 cars different?
2000 v70 GLT
1997 v70 AWD lpt
1995 850 T5
tardcart
Has thanked: 1 time
tardcart
Post by tardcart » Sat Apr 13, 2019 6:31 pm
not sure when boost pressure became part of the ECU input. 2000 im guessing, could be 99. Im only guessing, but people use the 99 and 98 ECU in 850's so must not have boost pressure input.
