2012 XC60 won’t start
I was driving home and had no issues until I was a couple miles from home. I had the ac on and suddenly the windshield got all fogged up. Then I smelled something burning (not sure what) but definitely not coolant, I had some coolant issues with my last Volvo so I’m familiar with that smell. I turned the ac off, got home, I left it running and popped the hood and there was smoke that appeared to be coming out of this one spot. I’ll post a pic. Next day, nothing, key works everything lights up but it won’t start. No other messages except what was already there (fill washer fluid). It’s got plenty of oil and coolant btw. Anyone know what this thing I have circled is? Thanks
- E0824DA6-5416-4014-AEA6-8C83926B8B2B.jpeg (185.61 KiB) Viewed 2024 times
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
Chris
The location you circled is above the compressor for the air conditioner
The 3.2 has a R.E.A.D. rear end ancillary drive
Which means that the serpentine belt is at the back of the engine above the transmission
As for the no start issues it seems that you had an electrical failure.
Depending on your level of experience you may want to get outside help
Let us know if you decide to tackle this yourself or what you find out
Good luck
Paul
Good luck
Paul
Thanks for the reply! I have almost zero experience lol so I’m having it towed to my mechanic, hopefully I’ll know something in a day or two.
That sounds expensive btw. Someone else I talked to said electrical too so that’s probably it.
I’ve only had this car about 6 months so I don’t know it’s history other than the carfax.
- 5504 Views
Last post by RickHaleParker
- 2084 Views
Last post by keng
- 4982 Views
Last post by djtomr941
- 2481 Views
Last post by mrbrian200
- 1298 Views
Last post by jgibbs2273
